Author Topic: Clutch  (Read 3405 times)
May 05, 2012, 04:36:07 pm
Jvan_wert
  • 18
Clutch
« on: May 05, 2012, 04:36:07 pm »
 Anybody here ever run a clutch from Vato Zone Ahem I mena Auto Zone? My clutch is looking a little tired and is oil soaked from a leaking rear main. Vato Zone has the kit for 75 buck where parts place wants 50 just for the disk. The pressure plate and flywheel looked oaky.
'85 Vanagon GL (2.0 ZETEC)
81' Rabbit 1.6D NA
'63 Bug (currently in jig saw puzzle mode)
Reply #1May 05, 2012, 05:32:30 pm
chopper03
  • 42
Re: Clutch
« Reply #1 on: May 05, 2012, 05:32:30 pm »
I am running the autozone clutch kit in a 1.6D Rabbit truck for three years now and no problems.
Reply #2May 05, 2012, 09:47:03 pm
bbob203
  • 1789
Re: Clutch
« Reply #2 on: May 05, 2012, 09:47:03 pm »
75? im seein 105 on the website... id like to know i need to put in a clutch before i sell one of my dubs.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3May 05, 2012, 10:41:43 pm
Re: Clutch
« Reply #3 on: May 05, 2012, 10:41:43 pm »
http://www.autopartsway.com/PartList.cfm?Volkswagen/1985/Jetta/Base/1.6L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Kit/pagenum1/tabS
Everything you need, for $96. Very good quality. My last 5 vw clutches have been through this website, I recommend them 100%.
Reply #4May 06, 2012, 05:15:37 am
Re: Clutch
« Reply #4 on: May 06, 2012, 05:15:37 am »
When I saw the title I kept thinking   10001110101   google clutch with those numbers and you'll understand... temple of the syrinx having the bake sale of the year...
I have had a Luk clutch set in my vw for 10,000 miles. I have had a Luk clutch in my 3/4 ton Chevy since 1998 and it still holds like day 1. I paid around 120.00 IIRC for my Luk set in the jetta. It was for a 96 aaz as I have that PP installed now, so it is the 210mm
Reply #5May 08, 2012, 09:35:18 am
92EcoDiesel Jetta
Re: Clutch
« Reply #5 on: May 08, 2012, 09:35:18 am »
Where are they located? I can't find one in their catalog for my 92 Eco. Shoudn't the one you listed work in mine?
Reply #6May 10, 2012, 07:18:14 am
Re: Clutch
« Reply #6 on: May 10, 2012, 07:18:14 am »
The eco should be 200mm? No? I have never used the us part of the site.. But they have the same stuff as the Canadian site.
Reply #7May 12, 2012, 04:20:05 pm
arb
Reply #8May 13, 2012, 09:16:18 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Clutch
« Reply #8 on: May 13, 2012, 09:16:18 pm »
You can get a new sachs clutch for $89 shipped from mjm autohaus.
Sent from my DROID X2
