Author Topic: HHO generator... Too good to be true??  (Read 5053 times)
April 24, 2012, 05:41:53 am
bbob203
  • 1789
« on: April 24, 2012, 05:41:53 am »
Anyone experiment with it??
http://www.youtube.com/embed/-3LVhNj5Hf0
Then theres this crazy guy...
http://www.youtube.com/embed/z99dQ_3ZaLA
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1April 24, 2012, 10:13:23 am
mtrans
  • 308
Re: HHO generator... Too good to be true??
« Reply #1 on: April 24, 2012, 10:13:23 am »
I dont want to look tube.usualy snake oil as i TRIED long time ago.
Only ,maybe way is some neat electronics,cell isnt so important,you`ll get some but veeery little.
do Bob Boyce’s Pulsed Electrolyser System   http://www.free-energy-info.co.uk/D9.pdf
I`ll improve my English
Reply #2April 24, 2012, 11:07:54 am
bbob203
  • 1789
« Reply #2 on: April 24, 2012, 11:07:54 am »
thanks exactly what i was looking for.
03 Jetta wagon TDi
Reply #3April 24, 2012, 01:30:15 pm
mtrans
  • 308
« Reply #3 on: April 24, 2012, 01:30:15 pm »
No problemo,If you can high electronic and make some job done write please.
Reply #4April 24, 2012, 05:39:49 pm
« Reply #4 on: April 24, 2012, 05:39:49 pm »
My friends put a HHO generator on their bus with a 5.9 cummins in it. They said they saw about a 1-2 MPG gain in fuel economy if I remember correctly. The bus is only getting 15MPG so it's a pretty nice gain. They built their own setup.
Reply #5April 25, 2012, 09:39:47 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: April 25, 2012, 09:39:47 am »
If you put a magnet around the fuel lines, most people will claim they see a mileage increase.   Most of these types of systems are based on user testimonials, not scientific testing.    I look at it this way - if you see the amount of water they put in a small container and connect to their fuel system, even if you could convert it to 100% hydrogen, ask how often they refill it.   Whether gas or diesel, most don't refill more than once a week.  So, how can you add such a small percentage of "fuel" to your system and gain such disproportionate increases?   If it's so great, quadruple the amount you put in and it would almost fill your fuel tank back up for you.   Ask what the BTU of "HHO" or "Brown's gas" is - bet you don't get an answer.     Most if all gains, even if they are properly tracked, can be explained by slight changes in driving style because everyone wants to see an improvement.
Calvin
91 VW Golf 1.6NA 5spd
Reply #6April 25, 2012, 10:04:06 am
« Reply #6 on: April 25, 2012, 10:04:06 am »
Looking at it objectively, first you have diesel fuel in your tank.  Sunlight, stored as BTUs in that fuel, is converted into motion by the engine with an efficiency of 30%ish.  Next that motion is converted into electricity by the alternator with an energy conversion efficiency of less than 60%.  Then that electricity is used to break the bond of the hydrogen and oxygen in water.  That conversion is relatively efficient at 80-94% efficiency.  You will then return the hydrogen to the combustion chambers and turn it back into motion at about 30% efficiency.  That cycle of crank power to electricity to HHO to crank power results in more than an 80% LOSS of energy.  The only reason people don't see a BIG hit in fuel economy is because they are converting very little of the engine's power.  If they increased HHO production they'd see bigger and bigger losses.  You'd be much better off installing magnets on your fuel lines.  At least those do nothing except add a small amount of weight to your vehicle.
« Last Edit: April 25, 2012, 11:14:03 am by libbydiesel »
Reply #7April 25, 2012, 01:01:26 pm
mtrans
  • 308
« Reply #7 on: April 25, 2012, 01:01:26 pm »
They try to get not 100% than 1000 and more % of electrodialise in spite of Farady low.
Reply #8April 25, 2012, 10:25:29 pm
« Reply #8 on: April 25, 2012, 10:25:29 pm »
Useful Government is useful.
EPA Evaluation Efforts
The EPA evaluates or tests products to determine whether their use will result in any significant improvement or detriment to fuel economy. However, the EPA cannot say what effect gas-saving products will have on a vehicle over time because it hasn't conducted any durability tests. It's possible that some products may harm the car or may otherwise adversely affect its performance. In fact, today's vehicles' emission control systems are very sophisticated and complex. They have On Board Diagnostic features that alert the driver to problems associated with the emission control and fuel delivery systems. Retrofit products may have an adverse effect on these systems.
Devices Tested by EPA
The following list categorizes various types of "gas-saving" products, explains how they're used and gives product names. Those with asterisks may save measurable, but small, amounts of gas. All others have been found not to increase fuel economy.
Air Bleed Devices. These devices bleed air into the carburetor. They usually are installed in the Positive Crankcase Ventilation line or as a replacement for idle-mixture screws.
The EPA has evaluated the following products: ADAKS Vacuum Breaker Air Bleed; Air-Jet Air Bleed; Aquablast Wyman Valve Air Bleed; Auto-Miser; Ball-Matic Air Bleed; Berg Air Bleed; Brisko PCV; Cyclone-Z; Econo Needle Air Bleed; Econo-Jet Air Bleed Idle Screws; Fuel Max*; Gas Saving Device; Grancor Air Computer; Hot Tip; Landrum Mini-Carb; Landrum Retrofit Air Bleed; Mini Turbocharger Air Bleed; Monocar HC Control Air Bleed; Peterman Air Bleed; Pollution Master Air Bleed; Ram-Jet; Turbo-Dyne G.R. Valve.
Vapor Bleed Devices. These devices are similar to the air bleed devices, except that induced air is bubbled through a container of a water and anti-freeze mixture, usually located in the engine compartment.
The EPA has evaluated: Atomized Vapor Injector; Frantz Vapor Injection System; Hydro-Vac: POWERFUeL; Mark II Vapor Injection System; Platinum Gasaver; V-70 Vapor Injector; SCATPAC Vacuum Vapor Induction System: Econo-Mist Vacuum Vapor Injection System; Turbo Vapor Injection System.
Liquid Injection. These products add liquid into the fuel/air intake system and not directly into the combustion chamber.
The EPA has evaluated: Goodman Engine System-Model 1800; Waag-Injection System*.
Ignition Devices. These devices are attached to the ignition system or are used to replace original equipment or parts.
The EPA has evaluated: Autosaver; Baur Condenser; BIAP Electronic Ignition Unit; Fuel Economizer; Magna Flash Ignition Control System; Paser Magnum/Paser 500/Paser 500 HEI; Special Formula Ignition Advance Springs.
Fuel Line Devices (heaters or coolers). These devices heat the fuel before it enters the carburetor. Usually, the fuel is heated by the engine coolant or by the exhaust or electrical system.
The EPA has evaluated: FuelXpander; Gas Meiser I; Greer Fuel Preheater; Jacona Fuel System; Optimizer; Russell Fuelmiser.
Fuel Line Devices (magnets). These magnetic devices, clamped to the outside of the fuel line or installed in the fuel line, claim to change the molecular structure of gasoline.
The EPA has evaluated: PETRO-MIZER; POLARION-X; Super-Mag Fuel Extender; Wickliff Polarizer [fuel line magnet/intake air magnet].
Fuel Line Devices (metallic). Typically, these devices contain several dissimilar metals that are installed in the fuel line, supposedly causing ionization of the fuel.
The EPA has evaluated: Malpassi Filter King [fuel pressure regulator]; Moleculetor.
Mixture Enhancers (under the carburetor). These devices are mounted between the carburetor and intake manifold and supposedly enhance the mixing or vaporization of the air/fuel mixture.
The EPA has evaluated: Energy Gas Saver; Environmental Fuel Saver; Gas Saving and Emission Control Improvement Device; Glynn-50; Hydro-Catalyst Pre-Combustion Catalyst System; PETROMIZER SYSTEM; Sav-A-Mile; Spritzer; Turbo-Carb; Turbocarb.
Mixture Enhancers (others). These devices make some general modifications to the vehicle intake system.
The EPA has evaluated: Basko Enginecoat; Dresser Economizer; Electro-Dyne Superchoke; Filtron Urethane Foam Filter; Lamkin Fuel Metering Device; Smith Power and Deceleration Governor.
Internal Engine Modifications. These devices make physical or mechanical function changes to the engine.
The EPA has evaluated: ACDS Automotive Cylinder Deactivation System*; Dresser Economizer; MSU Cylinder Deactivation*.
Accessory Drive Modifiers. These devices reduce power to specific auto accessories.
The EPA has evaluated: Morse Constant Speed Accessory Drive **; P.A.S.S. Kit**; PASS Master Vehicle Air Conditioner**.
Fuels and Fuel Additives. These materials are added to the gas tank.
The EPA has evaluated: Bycosin; EI-5 Fuel Additive; Fuelon Power; Johnson Fuel Additive; NRG #1 Fuel Additive; QEI 400 Fuel Additive; Rolfite Upgrade Fuel Additive; Sta-Power Fuel Additive; Stargas Fuel Additive; SYNeRGy-1; Technol G Fuel Additive; ULX-15/ULX-15D; Vareb 10 Fuel Additive; XRG #1 Fuel Additive.
Oils and Oil Additives. Usually these materials are poured into the crankcase.
The EPA has evaluated: Analube Synthetic Lubricant; Tephguard.
Driving Habit Modifiers. These are lights or sound devices to tell the driver to reduce acceleration or to shift gears.
The EPA has evaluated: AUTOTHERM**; Fuel Conservation Device; Gastell; IDALERT**.
Miscellaneous. The EPA has evaluated: BRAKE-EZ; Dynamix; Fuel Maximiser; Gyroscopic Wheel Cover; Kamei Spoilers**; Kat's Engine Heater; Lee Exhaust and Fuel Gasification EGR; Mesco Moisture Extraction System; P.S.C.U. 01 Device; Treis Emulsifier.
* Indicated a very small improvement in fuel economy but with an increase in exhaust emissions. According to Federal regulations, installation of this device could be considered illegal tampering.
** Indicated a very small improvement in fuel economy without an increase in exhaust emissions. However, cost-effectiveness must be determined by the consumer for a particular application.
« Last Edit: April 25, 2012, 10:27:46 pm by 745 turbogreasel »
