Author Topic: Boost controller lines  (Read 3536 times)
April 21, 2012, 05:36:07 pm
Dean Erickson
  • 58
« on: April 21, 2012, 05:36:07 pm »
I am going to put a boost controller on my 1.6 with a k 14 turbo. From what I understand you have to cut the metal line and put the controller in line. My question is will rubber fuel line work to tap into the metal line?
Reply #1April 21, 2012, 06:21:51 pm
Re: Boost controller lines
« Reply #1 on: April 21, 2012, 06:21:51 pm »
it will work, but vacuum line would be cheaper to get..
Reply #2April 21, 2012, 06:26:39 pm
bbob203
  • 1789
« Reply #2 on: April 21, 2012, 06:26:39 pm »
anyone ever get fancy and flare the lines and install it like that?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3April 21, 2012, 06:38:20 pm
« Reply #3 on: April 21, 2012, 06:38:20 pm »
why go thru the extra work?
Reply #4April 21, 2012, 06:51:14 pm
bbob203
  • 1789
« Reply #4 on: April 21, 2012, 06:51:14 pm »
no reason really.. except id totally do it that way when I get one if I had one of those fancy flaring tools that are mini hyrdalic pistons that flare the tubing. ;D
03 Jetta wagon TDi
