Author Topic: Wanted- power steering and a/c brackets with all pulleys  (Read 5231 times)
April 08, 2012, 05:26:26 pm
UnderPSI
  • 109
« on: April 08, 2012, 05:26:26 pm »
What the title says, let my know what you have. Thanks
Suzuki Samurai 1.6
Reply #1April 09, 2012, 09:35:23 am
Re: Wanted- power steering and a/c brackets with all pulleys
« Reply #1 on: April 09, 2012, 09:35:23 am »
i can get you the bracket, but nothing else. sorry if that doesnt help you, but just throwing it out there..
the a/c and non a/c crank and water pump pulleys should be the same. it should just be the bracket that makes it special. the non a/c bracket sets the alternator closer to the flywheel..
Reply #2April 09, 2012, 11:37:29 am
« Reply #2 on: April 09, 2012, 11:37:29 am »
brrackets for what year???  and wrong on pullies... ac wider for thicker belt then non ac..
Reply #3April 09, 2012, 11:43:02 am
« Reply #3 on: April 09, 2012, 11:43:02 am »
DOH!!
your right..
the crank and water pump pulleys are DIFFERENT, like mentioned.
Reply #4April 10, 2012, 07:07:31 am
UnderPSI
  • 109
« Reply #4 on: April 10, 2012, 07:07:31 am »
I need the a/c and power steering brackets and pulleys. Crank pulley as well, it's a mechanical 1.6 1984ish....
« Last Edit: April 10, 2012, 07:12:15 am by UnderPSI »
Suzuki Samurai 1.6
Reply #5April 10, 2012, 08:45:56 am
« Reply #5 on: April 10, 2012, 08:45:56 am »
power steering on a rabbit? good luck finding parts for that..
Reply #6April 10, 2012, 09:05:34 am
UnderPSI
  • 109
« Reply #6 on: April 10, 2012, 09:05:34 am »
Had all the brackets once, lost then when I moved.
Suzuki Samurai 1.6
Reply #7April 10, 2012, 09:11:08 am
« Reply #7 on: April 10, 2012, 09:11:08 am »
only seen a handful of rabbits with power steering..
Reply #8April 10, 2012, 12:19:19 pm
rs899
  • 647
« Reply #8 on: April 10, 2012, 12:19:19 pm »
I have the p/s bracket, pulley and pump from a gasser JH engine that came from an '84 Scirocco.  Does that work?
Reply #9April 10, 2012, 03:58:39 pm
UnderPSI
  • 109
« Reply #9 on: April 10, 2012, 03:58:39 pm »
Where does that put the pump on the engine?
Suzuki Samurai 1.6
Reply #10April 10, 2012, 11:26:41 pm
  • 2932
« Reply #10 on: April 10, 2012, 11:26:41 pm »
I was thinking the MK1 AC alternator brackets had an extra bolt hole on the bottom,
 like all the MK2s AC or not.
 They look similar to the Mk2 bracket so I might have confused them.
Reply #11April 11, 2012, 03:54:29 am
rs899
  • 647
« Reply #11 on: April 11, 2012, 03:54:29 am »
Well, under it.  It looks pretty much  like a MKII lashup, but I didn't compare them side by side
Reply #12April 11, 2012, 11:05:01 am
UnderPSI
  • 109
« Reply #12 on: April 11, 2012, 11:05:01 am »
That would work, will that work with a/c?
Suzuki Samurai 1.6
Reply #13April 15, 2012, 02:29:49 pm
ROBZUK
  • 5
« Reply #13 on: April 15, 2012, 02:29:49 pm »
I have the alt, crank and another pulley off my diesel swap. I can shoot a pic if you like. $25 shipped.
Reply #14April 15, 2012, 06:00:10 pm
UnderPSI
  • 109
« Reply #14 on: April 15, 2012, 06:00:10 pm »
Don't need the alt pulley, crank pulley for a/c?
Suzuki Samurai 1.6
