Author Topic: Vacuum Pump  (Read 3761 times)
March 22, 2012, 05:12:45 pm
TonyTDTruck
  • 110
Vacuum Pump
« on: March 22, 2012, 05:12:45 pm »
Where is the best place to buy a vacuum pump for my 1.9TD AAZ?
Can the drive shaft be replaced or do I need a new pump?
The damage is where the drive shaft of the vacuum pump plugs into the oil pump drive shaft.
Some how it got worn out.
p/n 028207A
Thanks
How do you wash a pressure washer?
And did you know that the 14th floor in a
hotel is actually the 13th floor!
Reply #1March 22, 2012, 05:14:54 pm
Re: Vacuum Pump
« Reply #1 on: March 22, 2012, 05:14:54 pm »
p/n 028207A
Thanks
oil pump drive tang wear is super common on these engines.
Reply #2March 22, 2012, 05:25:28 pm
TonyTDTruck
  • 110
Re: Vacuum Pump
« Reply #2 on: March 22, 2012, 05:25:28 pm »
Good to know R.O.R.-2.0.
Where can they be had? Or is used the only option?
Reply #3March 22, 2012, 06:06:51 pm
Re: Vacuum Pump
« Reply #3 on: March 22, 2012, 06:06:51 pm »
The ultra expensive route is the www.partsplanceinc.com IIRC I have the magazine and it is something in the neighborhood of high 200 dollar range.
Reply #4March 22, 2012, 07:23:38 pm
Re: Vacuum Pump
« Reply #4 on: March 22, 2012, 07:23:38 pm »
idk much about AAZ motors or parts, since they are a canada only thing.. i know alot about IDI engines in general, but thats about it.
im one of the WORST people to be asking about NEW PARTS, because i try to re-use or rebuild everything.. im one of the cheapest bastids on the forum.. what some would call FRUGAL, but i just call it CHEAP.
Reply #5March 23, 2012, 08:57:25 am
TonyTDTruck
  • 110
Vacuum Pump
« Reply #5 on: March 23, 2012, 08:57:25 am »
Holy smoke! $259 for a vac pump. For that price you can place a motor in the wind driven by a propeller while the car in in motion.
My troubles are getting worse. Where can I find a good used cylinder head? I have a shop looking at mine and they told me yesterday it's toast as well.
Looking on web sites, I see prices ranging from $750 to $1000 US. :(
Reply #6March 23, 2012, 09:34:32 am
Re: Vacuum Pump
« Reply #6 on: March 23, 2012, 09:34:32 am »
i have a GREAT casting that i might be persuaded to get rid of.. its all there, but it needs a couple things.
Reply #7March 24, 2012, 07:38:43 am
TonyTDTruck
  • 110
Re: Vacuum Pump
« Reply #7 on: March 24, 2012, 07:38:43 am »
Good to know about the bow tie slot. From the  feed back I'm getting it sounds like this is a common  or normal wear for this pump.
I found a new head assembly at boraparts.com for $650. This is a complete assembly. For the price it looks like a great deal.
Thanks
Reply #8March 24, 2012, 11:24:32 am
Thezorn
  • 381
Re: Vacuum Pump
« Reply #8 on: March 24, 2012, 11:24:32 am »
I have a vac pump that came off a an early 1.9 passat IDI that Im not going to use. You will just need to swap out the cap from your existing pump to this one, seeing how I needed it. If your interested shoot me a pm and we can work something out fro alot cheaper then there prices your finding ;D
Compounded 93 AAZ
Reply #9March 24, 2012, 12:06:38 pm
TonyTDTruck
  • 110
Re: Vacuum Pump
« Reply #9 on: March 24, 2012, 12:06:38 pm »
E-mail sent.
