Author Topic: Missing Main Bearing Cap-any remedy?  (Read 4666 times)
March 13, 2012, 08:03:23 am
motomike33y
  • 190
« on: March 13, 2012, 08:03:23 am »
Have a 1.6 block w/crank and pistons but discovered that I somehow am missing the middle cap on the main bearing.  I've read about the line-boring and matching of caps so am I SOL or can a different cap be used?  What options do I have?  thanks
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1March 13, 2012, 08:33:23 am
rallydiesel
  • 1880
Re: Missing Main Bearing Cap-any remedy?
« Reply #1 on: March 13, 2012, 08:33:23 am »
Find another cap and get it line bored. No other option.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 13, 2012, 10:17:33 am
motomike33y
  • 190
« Reply #2 on: March 13, 2012, 10:17:33 am »
assume that is a complicated and expensive process?
2012 golf tdi
Reply #3March 13, 2012, 04:58:12 pm
rallydiesel
  • 1880
« Reply #3 on: March 13, 2012, 04:58:12 pm »
Block needs to be bare and taken to a machine shop. Not super expensive, just lots of time and labour in the prep.
Reply #4March 14, 2012, 09:33:15 am
sdwarf36
  • 159
« Reply #4 on: March 14, 2012, 09:33:15 am »
We'd get $250 at our shop to line hone it. More if theres major complications.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #5March 14, 2012, 11:54:59 am
motomike33y
  • 190
« Reply #5 on: March 14, 2012, 11:54:59 am »
certainly an expensive lesson then for misplacing cap-block was only worth about $100-now minus $150 in value.  :(
2012 golf tdi
Reply #6March 14, 2012, 04:45:38 pm
pointynoggin
  • 93
« Reply #6 on: March 14, 2012, 04:45:38 pm »
I think that cap has the thrust brg too which you should consider.  you may have to get the flats milled to match and do a custom fit on the thrust brgs.  I'm not sure.
1991 Jetta 1.6TD, Giles Superpump,
Reply #7March 14, 2012, 07:24:18 pm
« Reply #7 on: March 14, 2012, 07:24:18 pm »
that was a point i was also going to bring up.. the thrust bearings are contained in the #3 journal and cap..
