Need some torque Specs...
Topic: Need some torque Specs... (Read 3353 times)
February 27, 2012, 07:53:14 pm
hippiekiller
February 27, 2012, 07:53:14 pm »
Can anyone please tell me what I should be torquing my exhaust manifold and cam retainer studs to?
And 15lbs is correct for the bearing caps?
And what does one seal cap #1 and #5 with? would rtv work?
thanks
95 jetta, 2"lift
92 dodge diesel too much to list
February 27, 2012, 08:01:20 pm
Re: Need some torque Specs...
February 27, 2012, 08:01:20 pm »
18ft-lbs...
no rtv ever.. just caps to head.. nothing else required...
February 28, 2012, 05:06:16 am
CrazyAndy
February 28, 2012, 05:06:16 am »
Quote from: CRSMP5 on February 27, 2012, 08:01:20 pm
18ft-lbs...
Like CRSMP5 said NEVER put sealant of any sort between a bearing cap and its sealing surface; the machining should be enough to provide enough of a natural seal. A little tiny bead in the corners where the seal sits (AFTER the cap is installed) helps seal the VCG if that's what you mean. Cam seal shoudn't need any sealant, though.
February 28, 2012, 06:37:41 am
hippiekiller
February 28, 2012, 06:37:41 am »
My book calls for sealant on #1 and #5, and there was some there from factory, thats all.
And just to clarify, I am torquing the studs into the cyl. head, and 16-18lbs is seeming like a lot.
Thanks
Last Edit: February 28, 2012, 06:40:23 am by hippiekiller
95 jetta, 2"lift
February 28, 2012, 10:22:19 am
February 28, 2012, 10:22:19 am »
I've thrown a little hylomar on the first cap, just a really, really thin layer, though my Bentley makes no mention of it.
16-18 foot pounds isn't all that much. Is your torque wrench calibrated from 5 ft/lbs? I get the feeling they aren't as accurate towards the bottom of the scale.
18 ft/lbs is spec for the manifold to head. I think you could get away with a little less. 15 ft/lbs for the cam caps.
February 28, 2012, 12:59:01 pm
February 28, 2012, 12:59:01 pm »
Studs should not be bottomed out IMO.
February 28, 2012, 12:59:55 pm
rodpaslow
February 28, 2012, 12:59:55 pm »
Don't worry they are M8 studs. they are good studs (12.9 minimum) and will have no problem taking 18 ft.lbs. If you've used new gaskets after the first heat cycle that (the torque) will have dropped a certain amount. I usually don't retorque anything unless I have leak issues with the new exhaust gaskets.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
