Author Topic: Jeremy's '84 m-tdi daily driver  (Read 16313 times)
January 21, 2012, 05:52:11 pm
« on: January 21, 2012, 05:52:11 pm »
Got her in 2007 as a gasser, and lookin pretty rough..
Screwed around as a teenager does and made it look even worse..
Filled in some of the body lines.. Which if I finish it, will look DAMN good the way I have it..
Painted it with a good 'ol roller and some Tremclad glossy ;)
Swapped in a 91 1.6 non-turbo hydro motor. (yah yah, no belt cover and no airbox either.. whatever.. lol)
Then I started to make it look nicer :) lol.
Found me some late Rabbit bumpers. and got some beauty fogs on there.
Wanna know what I hate!? Not being able to see while I'm backing up in the dark! BAMM back up spot light.
She's a workhorse too ;) That is 675lbs of steel in the trunk.. Oh hell yes.
I've had a few more dubs other than this one..
These next two pictures makes 6 dubs in my driveway at one time ;)
That's my story :D
« Last Edit: May 21, 2012, 06:45:43 pm by 8v-of-fury »
Reply #1January 21, 2012, 05:56:54 pm
Re: My 84 Daily Jetta
« Reply #1 on: January 21, 2012, 05:56:54 pm »
For the record, I did not crash that golf. I bought it that way not running for $200. took the motor and sat on it for years for my 84.
I drove the gold car all last summer, my true introduction to diesels. got that car for $100 out of a barn that it sat in for 6+ years. changed the oil and coolant and drove the hell out of it :)
the red mk1 is my brothers jetta, and we got the 92 red jetta on trade for the 98 shell. which i used the 92 TD motor for my bros diesel swap. then scrapped the 92.. and came out even on the money I used to buy the 98! lmao which i got not running for $400. Got it running drove it a few months then started tearing it down. kept the motor, trans and all the electrical stuff. After that i traded the interior from the shell to someone else for a running 84 diesel motor and trans.
quite the awesome time ive had learning volkswagens. NOW IM FREAKIN' PRO! lmao
Reply #2January 22, 2012, 12:52:16 pm
wdkingery
  • 494
« Reply #2 on: January 22, 2012, 12:52:16 pm »
GOOD GOD look at that hood up with all that snow! in Virginia, if there's that much snow, it means you are not working on yer car today..
Reply #3January 22, 2012, 04:21:18 pm
« Reply #3 on: January 22, 2012, 04:21:18 pm »
Omg, WD.. you would not believe it if I told you.. it was super cold last winter here.. and didnt snow that much lol.
HOWEVER! It was -25C when those two snowy pictures showing the 6 dubs at once was taken.. hence the girl with the jacket done right up lol.. and me laying on the ground with 5.. or maybe even 6 layers of clothing on!! LMAO
Reply #4January 22, 2012, 04:50:11 pm
« Reply #4 on: January 22, 2012, 04:50:11 pm »
Only good thing about snow and coveralls is that if you use the really gooey oily ones on the outside you can slide on your back real good to get under the car.  Oh, watch that tranny there.  Yeah and the cross member too.
I hate working in the snow.  But all this rain isn't any better.  Given enough cold snow is a bit better as it doesn't soak in as much.
Reply #5January 22, 2012, 08:53:23 pm
Baron VonZeppelin
« Reply #5 on: January 22, 2012, 08:53:23 pm »
8V you are a true blue dyed in the wool VW Diesel HardCore Specialist
There are almost as many Mk1 Jet Dzlz in your driveway as i have seen in my whole life in person. lol
Keep them freight trains rolling Man
^5
Won't be much longer til most of us are coming to you to help remind us of the stuff we've forgotten - that we thought we once knew -but can't remember if we knew it, or dreamed it.     :)
Reply #6January 23, 2012, 04:52:51 pm
« Reply #6 on: January 23, 2012, 04:52:51 pm »
haha, when my two other buddies come over 84 rabbit diesel and 82 jetta 1.7 CIS there is 5 a1's in the driveway lol.
Sadly I am getting rid of the gold 81.. I haven't the ability to keep it. I tried to sell it as a complete shell.. but no bites. So one more a1 is getting crushed. :(
Reply #7January 28, 2012, 02:56:12 pm
« Reply #7 on: January 28, 2012, 02:56:12 pm »
Reply #8February 18, 2012, 09:44:37 pm
« Reply #8 on: February 18, 2012, 09:44:37 pm »
Today the 84 got a AHU TDI  heart transplant :)!
Tomorrow I will get it running, and be driving it. Gotta love 8hr full engine swaps :)
Reply #9May 21, 2012, 07:29:48 pm
Re: Jeremy's '84 m-tdi daily driver
« Reply #9 on: May 21, 2012, 07:29:48 pm »
So really when you are elbows deep in an engine swap of this caliber, you do not have time to take pictures.. I only have these couple pictures to do anything with the actual swap.. Gasser mk1 passenger mount, new water pump and rear main. 200k km 210mm flywheel, hand freshened lol. Brand new 210mm sachs OEM clutch kit. To top of the tranny stuff a 1986 mk2 ACN transmission.
The night before I did the swap I drove my daily driver to the shop and hauled my pump off it and got a ride home with my brother. That night I dismantled my already franken-pump and made it an m-tdi one. It was a late 80's TD pump body, with a 91 NA lid on it. Of course fully shimmed governor and the fuel turned up as physically as high as it could go.. Any more and the idle got too high. I had the idle screws backed all the way out, and the throttle lever jumped back a spline so that more fuel screw could be turned in. I think even with the fully shimmed governor I was something like 3-4 full turns in from stock. Whhooooa! she flew for a non turbo lol. Sitting on my core support ready to go on the motor is a 1.6 TD pump body, with all the 1.9 AHU TDI internals, 1.6 lid and a mad whack boost pin by member 410 on here.
I drove it like this for about a month, and then when the weather got nice I decided to tear back in to it.. PLUS my modified throttle lever had been finished (also by member 410 on here) and was ready to be installed! Beside a stock one on the right, you can see that the ball end had been extended and the pivot hole in the side of the lever had been changed. Plus a few other key modifications like removing height from the lever so it would not hit the lid seeing as how it was being mounted sitting higher in the pump now. Modification to the LDA arm inside the pump lid had to be done as well. I have no pics of that, sorry. And the boost pin as well, on the right.
I had found a low low mileage 1.9AAZ pump body with zero main shaft play to use as my base for M-TDI Version 2.0. I had it totally apart and prettied up for when the lever got back to me :)
A little pump clearancing was needed in order to fit the newly modified throttle arm properly. A side by side of another nasty corroded pump, to see where the clearancing was needed for the new swing of the throttle arm.
All finished and buttoned up, on the car and running great.
Reply #10May 21, 2012, 07:32:37 pm
« Reply #10 on: May 21, 2012, 07:32:37 pm »
The car was off the road for a month while I frigged around with the pump. I took it off and fully apart 9 times in that month, to do more clearancing.. more issues. blah blah. Then I started blowing my boost pipe all the time, because it was only crappy ABS and I was now making too much power!
I drove the car for the first real time in exactly one month this Friday night on my way to a bush party.. It did great! I need a boost gauge though! lol.
Reply #11September 02, 2012, 01:39:33 pm
« Reply #11 on: September 02, 2012, 01:39:33 pm »
Reply #12September 04, 2012, 05:12:37 am
nathantheengineer
  • 61
« Reply #12 on: September 04, 2012, 05:12:37 am »
I don't know whether the problem is with my pc but i can't see most of your pictures, i just get the little red cross. anyone else having the same problem?
Cheers
nathan
Reply #13September 04, 2012, 07:47:22 am
« Reply #13 on: September 04, 2012, 07:47:22 am »
All the pictures are there for me, I think it is on your end sadly.
Reply #14September 14, 2012, 05:28:59 pm
  • 3468
    • McScrubbins Body Wash
« Reply #14 on: September 14, 2012, 05:28:59 pm »
Got the M-TDI ON DEEECKKK!!!!!!
