Author Topic: Jeremy's '84 m-tdi daily driver  (Read 16311 times)
Reply #15September 14, 2012, 05:29:24 pm
  • 3468
    • McScrubbins Body Wash
Re: Jeremy's '84 m-tdi daily driver
« Reply #15 on: September 14, 2012, 05:29:24 pm »
lol, that pump is really a diamond in the rough hahahah
Reply #16September 14, 2012, 05:35:01 pm
« Reply #16 on: September 14, 2012, 05:35:01 pm »
"Like" It is my favourite damn part.. but it died recently. An inner modification caused some metal to go through the pump and trash the vane pump.. causing no internal pressure.. :( So now I am rocking this Frankenshteenpompe. Good thing I got like 9 of these things.. lol
I just realized there is also no pictures of the Rover pump in here!
Sellers pictures before purchase, they suck what can I say.. lol. I'll have to get some updated better pictures while I am resealing it :)
Reply #17December 10, 2012, 08:38:42 pm
« Reply #17 on: December 10, 2012, 08:38:42 pm »
Mind the pen ;) GF was trying to be a fool lol. Powah Powah Powah!
« Last Edit: January 27, 2013, 07:21:02 pm by 8v-of-fury »
Reply #18January 27, 2013, 07:20:41 pm
« Reply #18 on: January 27, 2013, 07:20:41 pm »
Reply #19January 27, 2013, 07:45:26 pm
tyb525
  • 183
« Reply #19 on: January 27, 2013, 07:45:26 pm »
nice winterforce tires, is that timing belt roller a factory thing or did you make it?
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #20January 27, 2013, 07:48:03 pm
« Reply #20 on: January 27, 2013, 07:48:03 pm »
Those tires are like 5 winters old, insanely good value I got from them ;).
Timing belt roller is factory on the AHU/ALH pump bracket.
Reply #21February 22, 2013, 09:38:57 am
homerj1
  • 433
« Reply #21 on: February 22, 2013, 09:38:57 am »
Just looking for some more details on the bumper hitch install. It looks like you welded a bar and hitch to the bumper. Is that it? And how much can you tow - weight-wise? I suspect the trailer and atv's are at least 1500lbs?
Thanks
Aivars
« Last Edit: February 28, 2013, 08:23:43 pm by 8v-of-fury »
Reply #22February 22, 2013, 12:24:19 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Jeremy's '84 m-tdi daily driver
« Reply #22 on: February 22, 2013, 12:24:19 pm »
So you can just bolt a Rover pump on with no modifications? Is there a thread with more details? I have a mild curiosity about m-tdis and am thinking one will be my next project.
Sent from Outer Space!
Reply #23February 27, 2013, 11:41:17 pm
« Reply #23 on: February 27, 2013, 11:41:17 pm »
The rover has the larger pump snout, the same size as the ALH so the bracket needed boring. I also chose to use the AHU pulley and retain the twisting of the pump style timing setup.. as opposed to putting an ALH style on because I didn't have it. For this I had to slot the holes in the pumps case, not a big deal.. couple of holes and a round file..
Reply #24February 28, 2013, 08:29:50 pm
« Reply #24 on: February 28, 2013, 08:29:50 pm »
Thanks
Aivars
Sorry I missed this reply Aivars! Yes I will describe. What I did was get the smallest receiver welded to a piece of 1/4 or 3/8 steel bar. Because my bumper is aluminum, I then bolted it through the bumper (1/4" aluminum) with four 12.9 grade bolts. The bumper does flex a bit with extreme tongue weight.. but nothing outrageous.
Yeah, I guesstimate my trailer to weigh 1500-1600 ish all said and done. Which gives it about a 125lb tongue weight give or take, I can lift it with no problem. I can then stand me (260) and my brother (175) on the tongue and its still alright.. So that is a rough tongue weight of 560lbs.. WAY MORE THAN I'LL EVER HAVE BACK THERE.
Being that it is a smaller car, it really matters how you load the trailer.. compared to pulling it with my f-150, the weight could be anywhere and not even notice. Misplace the weight with the car and it throws the rear of the car all over.
is 15-1600lbs too much to be pulling with a 2100lb car? Absolutely. HAHA Good thing its all just 60-70km/h to where I ride, I wouldn't be doing this on the highway.. Also my trailer sticks out nearly two feet on either side of my car! LMAO
Reply #25March 02, 2013, 11:08:51 am
homerj1
  • 433
« Reply #25 on: March 02, 2013, 11:08:51 am »
Thanks Jeremy!
Reply #26March 08, 2013, 11:31:57 am
« Reply #26 on: March 08, 2013, 11:31:57 am »
Mud flaps! shoulda put them on the in the fall.. haha oh well!
HID cutoff in my Autopal EURO's. 55W 4300K Bi-Xenon.
From this to that in less than a week!!!
