Author Topic: tickey lifter?  (Read 3037 times)
October 02, 2011, 02:30:29 pm
Gizmoman
  • 1301
tickey lifter?
« on: October 02, 2011, 02:30:29 pm »
The engine is a 1.9 AAZ turbo in an 82 VW Westfalia. I was driving back home from a 1200 mile vacation in the Sierras and running intermittently into the 4000 RPM range. When we pulled off to get some lunch, I noticed a ticking noise.
I have no idea what it is and can only hope it's nothing serious. The ticking goes away when I let it idle downhill with no pedal. As soon as I put pedal to it, it shows up.
It runs fine otherwise, starts right up seems to have the same power.
Bad injector?, Stuck lifter - or something else.
Any thoughts appreciated.
JW
Reply #1October 02, 2011, 04:15:10 pm
Re: tickey lifter?
« Reply #1 on: October 02, 2011, 04:15:10 pm »
injector if it goes away when you let off the throttle..
if its a lifter, it will tick regardless of throttle position..
Reply #2October 02, 2011, 06:06:33 pm
Re: tickey lifter?
« Reply #2 on: October 02, 2011, 06:06:33 pm »
I agree. take your fuel lines off and run them in to a bottle of straight auto trans fluid.
Reply #3October 02, 2011, 07:29:19 pm
Gizmoman
  • 1301
Re: tickey lifter?
« Reply #3 on: October 02, 2011, 07:29:19 pm »
Thanks for the pointers
Will the AT fluid clean it?
If I discover which injector it is, can I simply buy a new one?
Reply #4October 02, 2011, 07:42:47 pm
wdkingery
  • 494
Re: tickey lifter?
« Reply #4 on: October 02, 2011, 07:42:47 pm »
yes i too have a tickey injector, that can get to a downright loud tick.
i have yet to do the ATF trick (was kinda waitin on mtrans to respond on that) but i think it will have some affect.
you should replace it.
i don't want to replace mine, as it's kinda hero'd in there
Reply #5October 03, 2011, 05:53:45 am
Gizmoman
  • 1301
Re: tickey lifter?
« Reply #5 on: October 03, 2011, 05:53:45 am »
Yeah - this is quite loud as well. Any leads on where to get one?
Should I replace them all?
Reply #6October 03, 2011, 07:35:29 am
Re: tickey lifter?
« Reply #6 on: October 03, 2011, 07:35:29 am »
Lookup Giles at Performance Diesel Markham, Ontario, Canada.
Reply #7October 03, 2011, 12:46:33 pm
Re: tickey lifter?
« Reply #7 on: October 03, 2011, 12:46:33 pm »
Do them all at the same time unless the others were very recently replaced.
