Author Topic: 1.6GTD head gasket and engine specs  (Read 4481 times)
September 26, 2011, 06:22:27 am
regcheeseman
  • 714
« on: September 26, 2011, 06:22:27 am »
I'm getting a MLS gasket made up for my 1.6 but my two manuals give conflicting info.
What is the correct thickness for a 3 notch GTD gasket - does that differ from a 3 notch AAZ gasket?
What is the bore size of the 1600 cylinders?
Reply #1September 26, 2011, 11:03:08 am
Re: 1.6GTD head gasket and engine specs
« Reply #1 on: September 26, 2011, 11:03:08 am »
76.48mm for a FRESH bore.
77.48 is max o/s on a 1.6, AFAIK..
Reply #2September 26, 2011, 07:34:42 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: September 26, 2011, 07:34:42 pm »
All fibre gaskets the same for all the 1.6 diesels 1.61mm max.
 Bores out to 77.5mm.
Everything the same on the diesel engines, ie RA SB, as well as the MF 1V etc Including rings.
The only difference I've found is  RA and SB have different pistons from the others.
Reg you've not replied to my pump cam lift question... :'(
Mark-The-Miser-UK
Reply #3September 27, 2011, 06:51:20 am
regcheeseman
  • 714
« Reply #3 on: September 27, 2011, 06:51:20 am »
Not been about for a bit, what question might that have been?
Reply #4September 27, 2011, 07:02:55 am
Mark(The Miser)UK
  • 1557
« Reply #4 on: September 27, 2011, 07:02:55 am »
Day release from doing porridge? :)
I was referring to your thoughts that  the injection pump cam heights for 1.6 pumps being mainly about 4mm, and not as I have seen so far 2.3mm. I was wondering if it was because of your dealing with lots of GTD pumps?
Mark-The-Miser-UK
Reply #5September 27, 2011, 01:58:19 pm
regcheeseman
  • 714
« Reply #5 on: September 27, 2011, 01:58:19 pm »
pumping porridge is nearer the truth!
Found your question and replied.
Reply #6September 27, 2011, 02:52:17 pm
Mark(The Miser)UK
  • 1557
« Reply #6 on: September 27, 2011, 02:52:17 pm »
I found it... now your 2 threads are next to each other!
What is the physical difference between GTD pistons and the rest? I assume you know as you seem to have the SW UK collection of VW diesel  engines. ;D
Mark-The-Miser-UK
Reply #7September 28, 2011, 06:38:06 am
regcheeseman
  • 714
« Reply #7 on: September 28, 2011, 06:38:06 am »
Rarely taken any pistons out of any block, never compared any either - sorry.
