Author Topic: FS: Brackets to upgrade MK1 w/16V 10.1's to Corrado rotors (and rotors) $99 shpd  (Read 5781 times)
September 15, 2011, 08:37:37 pm
AudiVWguy
I've got a set of these brackets and rotors for sale. They work great. Complete bolt on. You will need the calipers from
Scirocco 16V
Audi 4KQ 83-87
Audi Coupe GT 85-87
I can get these in a flat rate Priority Mail shipping box. (For US shipping)
Thanks for looking,
-Jeff
« Last Edit: September 16, 2011, 04:23:58 pm by AudiVWguy »
Reply #1September 15, 2011, 08:49:34 pm
Re: FS: Brackets to upgrade MK1 to Corrado rotors (and rotors) $99 shipped
« Reply #1 on: September 15, 2011, 08:49:34 pm »
ahhhhhhh some major misleading here...
calipers ok...
part caliper bolts too then that bolts to the adapter above... NO... thats corrado/vr6passat
next.. the carrier.. aka part i speak of above..
16v rocco, audi 4000 quattro.. is one that will fit the stock nuckle to get 10.1" front brakes..
the others, audi 5k, 16v jetta/golf.. mk3.. passat b3 16v.. will fit those adapters.. but only allow 10.1" rotors..
UNLESS those adapters move a 10.1" rotor set up to fit a 11" rotor.. then you need to know which carrier the adapter is made for as there is 2 different ones listed above..
now wanna fill in the info?? 100 shipped is not too bad a price for rotors/brackets.. but your wording has me messed up on whats supposed to fit them..
Reply #2September 15, 2011, 09:11:00 pm
AudiVWguy
« Reply #2 on: September 15, 2011, 09:11:00 pm »
Sorry, not trying to be misleading. I had 10.1's and built these brackets to use the 11 in rotors. I went to to Ebay to get the other applications besides 16V rocco and Audi 4K, that"s what they said. The VR6 is a completely different offset and won't work. I will get center to center  on the bolt holes measurements if that will help. Thanks for the help.
Reply #3September 16, 2011, 06:21:50 am
ok..  ;D  jetta 16v needs removed.. its a mk3 style set up...
so this converts a 16v rocco 10.1" set up to 11" thats good to know.. wish i had the coin to blow.. makes my 84 coupe easy upgrade to 11" rotors simple as well its already got 10.1s on it.. borrowed my collected for years 11" stuff to put on my toaster..
down the road/years i may have to contact you about making another set of adapters..
4kq is also any 83-87
also some 4k 2wd had a big brake option which used them also..
« Last Edit: September 16, 2011, 06:26:34 am by CRSMP5 »
Reply #4September 16, 2011, 09:45:40 am
the jetta 16v option is perfectly fine, and it IS different than the mk3 stuff. i have them on my car, and they are awesome.. but they only bolt to mk2/3 cars as far as im aware..
Reply #5September 16, 2011, 04:27:24 pm
AudiVWguy
I think I got this right now.
You guys are awesome.
Cheers,
-JB
Reply #6September 22, 2011, 09:41:21 am
GEE-BEE
  • 1604
[email protected] makes the adapters for the mk1 g60 calipers and disc
Not perfect but they fit
I just installed 16 v spindles and new bearings and hub
60.00 for spindles
40.00 for parts
50.00 for powdercoating...
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #7September 22, 2011, 12:48:32 pm
60.00 for spindles
40.00 for parts
So are you selling something or just bragging? If you're selling you should create your own thread.
Reply #8September 22, 2011, 01:58:55 pm
gee-bee correct.. i got one of his kits 10 or so years ago.. but a big but.. this one uses the 16v rocco 10.1" caliper carriers and moves them to 11" position.. so instead of having to find roddo/vr6 passat carriers this is a convert your mk1 10.1" to 11" conversion... why i was intrigued with what this was with my inital post..
Reply #9September 22, 2011, 06:47:11 pm
AudiVWguy
I think GEE-BEE is illustrating his solution to the upgrade. How much did it cost for his adapters? Still had to buy rotors, right?
Reply #10September 22, 2011, 08:39:02 pm
rotors and roddo/vr6 passat calipers and carriers.. so way way more then your offer sir.. :D
think his adapters were 50ish when i got them many years ago..
trust me your set up intrigues me... but work slow.. few days good then couple crappy... if i hd a week or 2 of good id buy.. but knowing work drys up by turkey day.. i has to pass for now
Reply #11October 24, 2011, 08:57:05 pm
GEE-BEE
  • 1604
I Purchased a set of seats , rotors and calipers for 400.00
Just purchased a new set of pads and brembo rotors for all four
I think the adapters were like 65.00
way to much brake for the caddy
Giles Pump OHC
MK1 JETTA DASH
