k03 turbo from an AHU to AAZ
Topic: k03 turbo from an AHU to AAZ (Read 4938 times)
September 07, 2011, 05:48:20 pm
paolomarks
September 07, 2011, 05:48:20 pm »
I have a diesel vanagon with an AAZ from a 96 golf. The turbo is a k03 and needs new turbines and shaft. I'm having trouble finding these parts. Any ideas? How compatible is this engine with say a turbo from an AHU. would I need new manifolds/ downpipe flange to run an AHU turbo. ( I would also have to have it clocked since my engine is at 45 degrees. Thanks, Paolo
September 07, 2011, 08:48:37 pm
Re: k03 turbo from an AHU to AAZ
September 07, 2011, 08:48:37 pm »
The AHU manifold and turbo will physically bolt to the AAZ head.. I am unsure on fitment and what not.. The k03 on the tdi manifold is low mounted so im not sure how it will work. Are you trying to replace the k03 that originally came on the aaz? I think their fairly different?
September 08, 2011, 02:16:37 pm
paolomarks
September 08, 2011, 02:16:37 pm »
yes i'm trying to replace or repair (new turbine shaft assembly) the k03 that originally came on my AAZ. Paolo
September 08, 2011, 02:38:05 pm
Henchman
September 08, 2011, 02:38:05 pm »
They sell them on ebay fairly cheap....
Ian
September 08, 2011, 02:39:49 pm
September 08, 2011, 02:39:49 pm »
Quote from: Henchman on September 08, 2011, 02:38:05 pm
Ian
they sell LOTS of 1.8T K03 turbos on ebay.. CHEAP.
the diesel versions, not soo common..
September 08, 2011, 02:48:48 pm
Henchman
September 08, 2011, 02:48:48 pm »
I meant the shaft and impellers..... but they may be different also!
What is your timeframe for needing one? I have a few k03s right now, but won't know what I have surplus for a few weeks.
Ian
September 08, 2011, 05:50:50 pm
paolomarks
September 08, 2011, 05:50:50 pm »
can anyone verify whether the shaft and impellers are the same for the k03 turbos that came on the the AAZ and the 1.8t. Paolo
September 08, 2011, 09:41:05 pm
GEE-BEE
September 08, 2011, 09:41:05 pm »
ASK GPOPSHOP.COM
JERRY
I SEE NEW KO3 DIESEL TYPE FOR
http://cgi.ebay.com/ebaymotors/Borg-Warner-Turbo-K03-Audi-VW-1-9L-TDI-AAZ-1993-1999-/280477674890?pt=Motors_Car_Truck_Parts_Accessories&hash=item414dc5ad8a
I would make a offer on these , they have been sitting there for awhile
Last Edit: September 08, 2011, 09:47:59 pm by GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
