Author Topic: FS Turbo  (Read 6475 times)
September 06, 2011, 06:04:45 pm
abnkeis
FS Turbo
« on: September 06, 2011, 06:04:45 pm »
I have I believe a k24 turbo, the number on it is kkk  5324 101 50 96.  It's in good shape with no noticeable shaft play.
$150
« Last Edit: September 07, 2011, 08:04:42 pm by abnkeis »
Reply #1September 06, 2011, 07:51:20 pm
Blocksmith
  • 261
    Wrench Lurker
Re: FS Turbo
« Reply #1 on: September 06, 2011, 07:51:20 pm »
pics?
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2September 06, 2011, 08:04:19 pm
abnkeis
Re: FS Turbo
« Reply #2 on: September 06, 2011, 08:04:19 pm »
Should have pictures up by tomorrow.
Reply #3September 07, 2011, 08:45:13 pm
spencebm
  • 686
Re: FS Turbo
« Reply #3 on: September 07, 2011, 08:45:13 pm »
Is it just me or does that not look like a vw turbo?
Ben Spencer
Reply #4September 07, 2011, 08:52:31 pm
abnkeis
Re: FS Turbo
« Reply #4 on: September 07, 2011, 08:52:31 pm »
I don't know for sure. I got it with a parts car (91 Jetta) that I bought a few years ago. I was told it was a k24 for the mk2.
Reply #5September 07, 2011, 09:31:17 pm
RustyCaddy
  • 395
Re: FS Turbo
« Reply #5 on: September 07, 2011, 09:31:17 pm »
Maybe try contacting KKK-BorgWarner (turbodriven.com)
Reply #6September 07, 2011, 11:16:24 pm
Blocksmith
  • 261
    Wrench Lurker
Re: FS Turbo
« Reply #6 on: September 07, 2011, 11:16:24 pm »
is there no i.d. plate riveted onto the compressor housing? ??? it should say right on there what model it is... at least my k14 does...
do you have pictures of the hot side you could put up?
« Last Edit: September 07, 2011, 11:27:45 pm by Blocksmith »
Reply #7September 07, 2011, 11:29:52 pm
Wayland
  • 364
Re: FS Turbo
« Reply #7 on: September 07, 2011, 11:29:52 pm »
It appears to be off a Quantum. It has the special oil return fitting on the bottom with the support bracket hole. Should work fine on an MkI-II car, but the orientation of the housings would need to be changed.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #8September 08, 2011, 06:20:43 pm
spencebm
  • 686
Re: FS Turbo
« Reply #8 on: September 08, 2011, 06:20:43 pm »
I think you are correct
Ben Spencer
Reply #9September 09, 2011, 08:04:59 am
clarkrep
  • 117
Re: FS Turbo
« Reply #9 on: September 09, 2011, 08:04:59 am »
I'll put in a good word for an honest and fair seller. (:
I have bought a couple things from him and have been satisfied.
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #10September 09, 2011, 07:08:58 pm
damac
  • 531
Re: FS Turbo
« Reply #10 on: September 09, 2011, 07:08:58 pm »
If I have a stock setup with t3, can I take this turbo and mount it all up to my parts without modifications?
Or am I going to need to hunt down hoses, oil feed and return lines, etc.?
1985 turbo diesel jetta
Reply #11September 09, 2011, 10:53:35 pm
abnkeis
Re: FS Turbo
« Reply #11 on: September 09, 2011, 10:53:35 pm »
Hey, thanks for the kind words!!!
Reply #12September 09, 2011, 10:56:01 pm
abnkeis
Re: FS Turbo
« Reply #12 on: September 09, 2011, 10:56:01 pm »
I would think it would go together without much modification, but hopefully someone on here with more knowledge can chime in and answer better than I can.
Reply #13September 18, 2011, 07:25:39 pm
abnkeis
Re: FS Turbo
« Reply #13 on: September 18, 2011, 07:25:39 pm »
bump
Reply #14September 18, 2011, 09:49:14 pm
damac
  • 531
Re: FS Turbo
« Reply #14 on: September 18, 2011, 09:49:14 pm »
Sucks because I need one other than the t3 I believe for my stock setup and type of driving, and since I broke the damn boss off one of the oil line fitting and have it jbwelded.  But I haven't a clue on how to research to make sure I can somehow take this and make it work on my jetta.
