Author Topic: Any idea what turbo came stock on a 200sx?  (Read 7476 times)
September 04, 2011, 05:03:05 pm
« on: September 04, 2011, 05:03:05 pm »
i have a small turbo off a CA18 nissan 200sx..
anyone know anything about it? its a little garrett turbo.. idk, maybe a T2?
Reply #1September 05, 2011, 11:02:52 am
mystery3
  • 774
Re: Any idea what turbo came stock on a 200sx?
« Reply #1 on: September 05, 2011, 11:02:52 am »
The good people at google say it's either a t2 or a t25. Any p/n's?
Reply #2September 05, 2011, 10:46:34 pm
« Reply #2 on: September 05, 2011, 10:46:34 pm »
its a T2.. a little looking on wikipedia (friggen encyclopedia no less) lead me to the answer..
a little reading about the CA18ET told me what i wanted to know about the turbo. now i need to find some maps, and figure out how much air this thing is good for.
is this T2 turbo going to be similar to a factory VW diesel K14, or T2, if it were fitted to a diesel engine?
or will it not spool correctly since its a gasser turbo? ive heard gasser turbos dont spool up the same as diesel turbos..
Reply #3September 06, 2011, 12:57:08 pm
« Reply #3 on: September 06, 2011, 12:57:08 pm »
i did a search and this thread seems to conclude that gas turbos don't work on diesels
http://www.vwdiesel.net/forum/index.php?topic=28645.0
Reply #4September 06, 2011, 08:26:29 pm
« Reply #4 on: September 06, 2011, 08:26:29 pm »
that was a BIG T3 off a 2.5L engine.. it would have been horrible on a diesel.
im talking about a wee little T2 is all.. its off a similarly sized (1.8L) engine also. much closer in size than a 1.6 and a 2.5
but it doesnt even matter, the T2 is going on my 86 GTI. i re-drilled the flange on a stock single downpipe manifold to fit the turbo.
i have all the bits needed to convert CIS-Lambda to be boost friendly also.. so all i need to do is put all of it together, and get it running.
its gonna be sweet having 2 BOOSTED CARS!
Reply #5September 07, 2011, 08:43:45 am
« Reply #5 on: September 07, 2011, 08:43:45 am »
that guy was using the smaller mitsubishi turbo, the size of the engine a turbo comes from doesn't give u anymore than a vague idea of how well it will work.
obviously tho a t2 off a 1.8 nissan will work well on a 1.8 vw, aside from that i'm sure the nissan probably revs 1000rpms higher and flows much better, but when you're deal with that small of a turbo its kind of irrelevant
Reply #6September 07, 2011, 11:32:14 am
bgbmxer
  • 107
« Reply #6 on: September 07, 2011, 11:32:14 am »
that big turbo is on that 1.6 diesel now and spools just fine even tho its a gas turbo and wont work. from my experiance the stock turbo thats on the sr20det is rather small but that engine flows extremely well and revs very high.
the 2.5 engine had a mitsu turbo which is just a hair smaller than a t3 is and 2.2 came with a decent sized t3. the super 60 is what i would call a large t3. the mitsu im using has some lag yes but im using a large front mount. i will have a video of it not spooling up at all soon.
the size of the displacement is not so relavent. the 2.2 and 2.5 share the same head and everything only difference is the 2.5 has more stroke. the mitsubishi was put on the 2.5 for basically instant spool. faster than the vnts that were on the 2.2s in fact and were out of breath by the time 4 grand came around.
the best thing about the bigger gas turbos turbine side is the lower egts i seem to be seeing at around 20 pounds of boost.
look at the compressor map. nothing else.
« Last Edit: September 07, 2011, 11:44:51 am by bgbmxer »
Reply #7September 07, 2011, 11:50:57 am
« Reply #7 on: September 07, 2011, 11:50:57 am »
were not talking about SR20s tho..
and glad your turbo worked out for you..
that mitsu turbo has gotta be way out of its efficiency zone @ 20 psi tho..  there only efficient till about 15psi, or so ive read..
Reply #8September 07, 2011, 12:10:16 pm
bgbmxer
  • 107
« Reply #8 on: September 07, 2011, 12:10:16 pm »
thats why i run around 15 usually. it seems to just be working great around then tho. i might try it higher if i get gutsy. i might put the garrett on the car if i get bored sometime since i know its good up into the 20s.
the sr20 is the one most people run because they ditch the CA18. my friend had one make over 500 horsepower to the wheels. my point is that they flow alot of air and rev very high.
im actually running the front mount off his old car on the rabbit right now.
that turbo will probably work great for what your looking to do be really torqey down low and have no top end.
Reply #9September 07, 2011, 12:54:37 pm
« Reply #9 on: September 07, 2011, 12:54:37 pm »
im honestly glad that you proved me wrong.. it means i have more useable turbos for my diesel.. sorry i was being a nay-sayer the whole time.. i was just going by what someone (who i thought knew what they were talking about) had told me about putting gasser turbos on a diesel engine.. im glad it indeed DOES work tho..
but, im not talking about SR20s, or CA18s or anything like that.. im simply talking about the turbo off a CA18.. i have it in my possession, and its bolted to an 8v VW exhaust manifold.. thats cool that the SR20 turbo is small, and can keep up with HIGH rpms..
and what do you mean about the turbo having no top end? im not going to be spinning the engine past the stock red line anyways..
are you saying that its gonna run out of breath before the rev limiter?
Reply #10September 07, 2011, 02:47:14 pm
bgbmxer
  • 107
« Reply #10 on: September 07, 2011, 02:47:14 pm »
that turbo if im not mistaken is smaller than the mitsu im running on the diesel and they ditch that like the plague because it spools super quick but makes no real power. a decent sized t3/t4 has decent spool on one of those motors.
my experience with having no top end would be with my stock shelby charger. it would spool up super quick with the stock garrett but even with the stock head the turbo would fall off by the top of fourth and fifth gear in the higher rpms. it just didnt make enough power up there because it was so small. id rather have a car that has some lag time and hits like a freight train im fine with waiting or downshifting. when the other guy gets into the higher rpms where your going to be at for longer before you change to the next gear i dont want to be out of my powerband. the car would rev to 7 grand but just didnt pull past 5 and felt like a dog. first through third was great but after that nothing. i was out of the efficiency of what that turbo could do because it was to small.
and as i said before if the head intake and exhaust wouldnt have been ported like crazy this turbo wouldnt have worked. it would have been useless
« Last Edit: September 07, 2011, 02:49:51 pm by bgbmxer »
Reply #11September 07, 2011, 03:40:48 pm
« Reply #11 on: September 07, 2011, 03:40:48 pm »
sr20 and ca18 had similar turbos, it really depends what ca18 it came from tho
Reply #12September 08, 2011, 12:33:00 pm
« Reply #12 on: September 08, 2011, 12:33:00 pm »
is there more than one CA18ET?? it was a single cam, 8v 1.8L nissan engine.. non-intercooled, idk what else to tell you about it..
Reply #13September 08, 2011, 03:10:23 pm
bgbmxer
  • 107
« Reply #13 on: September 08, 2011, 03:10:23 pm »
either way id go with a slightly bigger turbo i would think. depends if you make the top end flow any better i guess.
Reply #14September 08, 2011, 04:47:14 pm
« Reply #14 on: September 08, 2011, 04:47:14 pm »
im not doing anything to the engine.. im bolting a turbo on, making oil lines, hooking up the boost sensing WUR, and installing a boost gauge..
im not building an engine for boost, im gonna see how much power i can get out of a bone stock engine..
im not building a race car. i just want more than 85 rompin', stompin' horsepower.
honestly, the engine spends most of its time under 4k rpms anyways..
is it really gonna be THAT bad? is it gonna be all out of boost before i hit the factory 6250 rpm rev limiter?
the next engine i build for the car is going to be an ABA/16vT.. it WILL be built specifically for boost.. and will have a better suited turbo on it..
im just making due with what i have for now..
my turbo choices are:
T2 off the nissan (small crack in in wastegate, otherwise in VERY good shape)
T3 off a 2.2 chry (needs rebuild)
TE04H off a 2.5 chry (needs the band clamp that holds the exhaust housing to the center section, and a wastegate can)
K24 off a VW diesel (boosted fine, no issues after i fixed the wastegate)
K26 off an audi quattro (unknown condition, no wastegate)
what turbo, of the 5, is best suited for a stock GX code 1.8L VW 8v engine?
