TDI Engine -General Info
pulse time land rover pump on tdi
Topic: pulse time land rover pump on tdi (Read 2955 times)
August 25, 2011, 06:35:00 pm
hustonr123
August 25, 2011, 06:35:00 pm »
I just recived my mac tools pulse adaptor from ebay. I have been wanting to see where the dynamic advance is. My problem is when I hook up everything I get a 0 reading at idle but when I rev it and adjust the timing light advance up it dosent move the flywheel mark the right direction. I then tried the timing light on a gasser and worked prefectly. Has anybody ran into this? I am sure that this thing has to be advancing it runs way to good to be loosing timing in higher rpms. When I get to work tommorow I will try the snap on digital light we have. It has + and - degrees.
August 28, 2011, 09:38:47 am
hustonr123
Re: pulse time land rover pump on tdi
August 28, 2011, 09:38:47 am »
today I tried my pulse adaptor on my 82 rabbit at idle it reads 15btdc reving it the advance goes into the 20s btdc so that tells me my mtdi pump is not advancing and prob retarding timing as it revs. Im sure people on this fourm is using land rover pumps and got them tweaked good. help please
August 28, 2011, 12:43:37 pm
August 28, 2011, 12:43:37 pm »
i set my inital timming to 118... no timming light on mine.. so no idea.. but happy with how it runs.. got almost 5k on it since th ebuild.. only like 60 or so miles till 5k..
August 28, 2011, 02:07:15 pm
hustonr123
August 28, 2011, 02:07:15 pm »
mine starts easy super easy just loses power in high rpms
August 28, 2011, 08:47:30 pm
August 28, 2011, 08:47:30 pm »
gps has mine at 104 till the cross winds picked back up and i backed off that was pulling from 75ish in 5th .. i still had more to go.. via gps.. 3rd good for 78mph..
