Author Topic: Steering bearing or something w/ pics  (Read 5271 times)
August 20, 2011, 04:24:59 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: August 20, 2011, 04:24:59 pm »
Can someone tell me the part number or where to get this... its worn out. i can shake the steering wheel. it looks like a bearing or such.
its right under the dash.
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1August 20, 2011, 05:49:52 pm
Re: Steering bearing or something w/ pics
« Reply #1 on: August 20, 2011, 05:49:52 pm »
http://www.vwdiesel.net/forum/index.php?topic=29782.0
she was having a problem and listed a part number mid thread. Don't know what to tell you.
Reply #2August 20, 2011, 07:00:27 pm
« Reply #2 on: August 20, 2011, 07:00:27 pm »
Hey there are only half the needle bearings in there that it should have.  Where'd day go?
Reply #3August 20, 2011, 07:10:35 pm
dankcorey22
  • 379
    Cummins!
« Reply #3 on: August 20, 2011, 07:10:35 pm »
Thank for the replies! the rest of the damn things up in there!
Reply #4August 21, 2011, 11:02:01 am
« Reply #4 on: August 21, 2011, 11:02:01 am »
looks to be the right amount of rollers in the race.. some bearings are built like that..
its cheaper to build one race that fits lots of bearings, rather than 2 different races..
Reply #5August 25, 2011, 06:47:15 pm
« Reply #5 on: August 25, 2011, 06:47:15 pm »
if you shove it back up and in there does it work to stop the moving of the steering shaft?
Reply #6August 25, 2011, 08:22:28 pm
« Reply #6 on: August 25, 2011, 08:22:28 pm »
that is what I would do and then does there happen to be some sort of keeper that needs to go in there as well?  Or is that yellow jobby have a screw on it that keeps it up there?
Reply #7August 25, 2011, 08:30:10 pm
« Reply #7 on: August 25, 2011, 08:30:10 pm »
i had this happen. Shoved it bakc in there and held it in with a ziptie or two on the shaft.
Reply #8August 26, 2011, 05:44:17 am
veector
  • 95
« Reply #8 on: August 26, 2011, 05:44:17 am »
had the same thing happen to me when i was swapping steering columns, just shove it in, ziptie or two to keep it there and you're golden. throw some grease on it for added smoothness :P
1981 Jetta D
1997 Jetta TD
Reply #9August 26, 2011, 06:39:10 pm
dankcorey22
  • 379
    Cummins!
« Reply #9 on: August 26, 2011, 06:39:10 pm »
I just put a hose clamp on mine haha
Reply #10August 27, 2011, 10:24:53 pm
maxfax
  • 2126
« Reply #10 on: August 27, 2011, 10:24:53 pm »
Hose clamp FTW..  I was tempted to be good and actually replace that bearing once upon a time.. Then they were I think $30...   75 cent hose clamp works just fine for me...
« Last Edit: August 27, 2011, 10:26:38 pm by maxfax »
Reply #11September 20, 2011, 02:26:26 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #11 on: September 20, 2011, 02:26:26 pm »
I like the hose clamp method myself also. Plus, that bearing is a total PITA to install if you use a new one.
