is this still a good donor for a 11mm pump swap?
Topic: is this still a good donor for a 11mm pump swap? (Read 2740 times)
August 18, 2011, 02:21:15 pm
carrizog60
August 18, 2011, 02:21:15 pm »
hi
when doing a plunger swap do i need the head or can i put my head and all the other bits of the pump donor?
because of this:
thanks
Portugal
August 19, 2011, 09:08:22 am
Re: is this still a good donor for a 11mm pump swap?
August 19, 2011, 09:08:22 am »
that head has an 11mm bore, for an 11mm plunger.
does your other head have an 11mm bore? if not, then no dice. usually the pump head, and plunger are manufactured as a matched set..
August 20, 2011, 02:03:57 am
carrizog60
August 20, 2011, 02:03:57 am »
ok,thanks.
it was going to serve as a donor for a bigger head swap but if its unmatch then bad luck.
is that such a difference that cant be done?
Portugal
August 20, 2011, 07:38:14 am
carrizog60
August 20, 2011, 07:38:14 am »
that one as,from what i can see, a broken delivery valve right?
if i put the aaz delivery valves that can work?or is going to spray diesel everywere from there?
Portugal
August 21, 2011, 10:58:34 am
carrizog60
August 21, 2011, 10:58:34 am »
no one?
Portugal
August 21, 2011, 11:16:09 am
August 21, 2011, 11:16:09 am »
well, you need to get that DV out first..
August 21, 2011, 11:50:25 am
carrizog60
August 21, 2011, 11:50:25 am »
i can take it out.
other than that should be ok?
Portugal
August 21, 2011, 11:56:33 am
August 21, 2011, 11:56:33 am »
start experimenting.. let us know.
its not going to blow up in your face like a bomb.. its either going to work, or not going to work..
August 22, 2011, 05:37:59 am
carrizog60
August 22, 2011, 05:37:59 am »
dont want to spend 50 or more euros on a chance...
its on ebay still
Portugal
