Author Topic: 82 1.6 dsl Power Brake Booster Upgrade  (Read 10832 times)
August 06, 2011, 09:21:04 pm
southernman
  • 72
« on: August 06, 2011, 09:21:04 pm »
Guys,
I have a '82 Rabbit P/U with the 1.6 dsl; the brake booster is very rusty, and I'd like to replace it.
However, I'd really like to know if later model master cylinders and boosters are an option for this truck. I figured, while I have the booster out, I might as well replace the MC as well.
Anybody out there have experience using the later model parts and know what parts will fit ?
Thanks for any help guys !
Southernman
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
Reply #1August 07, 2011, 04:46:36 am
Re: 82 1.6 dsl Power Brake Booster Upgrade
« Reply #1 on: August 07, 2011, 04:46:36 am »
81-84 westy bunny has a goofy pedal set to go with its goofy booster.. gotta switch it too...
aka german pedals, booster/master gotta be switched with all 3 parts... not one or 2 but all 3...
75-84 brake lights on master for german..
85+ cabby/rocco has brake light switch on pedal like yours.. and should be a 22mm master too..
hope the info helped...
if you change the pedal set.. make sure to reweld/strengthen the clutch tube on it also...
Reply #2August 07, 2011, 07:49:14 am
« Reply #2 on: August 07, 2011, 07:49:14 am »
Words to live by: Just because you paid a lot of money for it doesn't mean it's any good, it just means you paid a lot of money for it.
Often it seems that older parts were built to a much high quality so it is best to freshen them up rather then just replace them with new stuff.
Reply #3August 07, 2011, 09:16:39 am
« Reply #3 on: August 07, 2011, 09:16:39 am »
if your master cylinder is not bad, its a waste of time to replace it..
Reply #4August 07, 2011, 09:07:39 pm
southernman
  • 72
« Reply #4 on: August 07, 2011, 09:07:39 pm »
Guys, I appreciate the feedback.
I still can't tell if the master cylinder is leaking or the wheel cylinders. I plan on crawling under it this weekend to try and figure it out.
Is there a booster rebuild kit available, or would I have to send it off to a specialty shop to have them perform such work ?
D
Reply #5August 07, 2011, 10:00:04 pm
Powered by Spearco
  • 1203
« Reply #5 on: August 07, 2011, 10:00:04 pm »
If you plan on replacing the master cylinder, that is if its the part that needs replacing and not the booster or wheel cylinders, go to NAPA and get their brake master cylinder. Its a factory rebuilt unit and is a direct bolt on affair. As far as the booster. Unbolt the master and take a peek inside. If theres rust, then do the upgraded German style booster and MC from Cabbys or Roccos. Thats what I did and the brakes feel better than the stock US brake system.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #6August 07, 2011, 10:10:45 pm
« Reply #6 on: August 07, 2011, 10:10:45 pm »
ALSO... if you replace the mc.. DO NOT i repeat DO NOT give them a core... wait on that.. i went thru 3 of them there junk reman/new masters on my toaster.. it uses westy master/booster/pedals..
why... simple.. the rubber gromets that fit the bottle do not fit for crap... they will leak fluid between the rubber gromet and the master... the 3rd one was so freegin hard to put the bottle in that it actually sealed.. if i have to take it apart ever again.. will need a new bottle... it will break it.. and no the new ones are different size vs original..
if i had not spent the time building my clutch master brackets and all on the crappy us pedals i would have converted to my NIB german ones i have for my 84 coupe... the booster porcelin is cracked in it..  :-X and leaks vacume when brakes applied..
Reply #7August 15, 2011, 10:32:35 pm
nathan_b
  • 361
« Reply #7 on: August 15, 2011, 10:32:35 pm »
chris, they sell grommets, like $2, and you don't have to wait a week for shipping.. ;D
Reply #8August 16, 2011, 07:12:28 am
« Reply #8 on: August 16, 2011, 07:12:28 am »
the problem is advance/autozone ones are different then stock vw ones.. bigger diameter.. kind like a dime vs quarter in size.. the issue is the bottle was designed for dime sized ones.. push bottle in and it presses grommet into the hole... well when you use a quarter sized ones.. that does not work so well...  :(   why the last one was so tight it worked.. vs the others that fit was like stock..
Reply #9August 17, 2011, 10:25:16 pm
nathan_b
  • 361
« Reply #9 on: August 17, 2011, 10:25:16 pm »
I think the whole design is kinda stupid, someone should cast some with the reservoir built in, but def make 'em mk2-3 style, becaust mk1 masters, especially bendix SUX, adjustable pushrod and such...
Reply #10August 21, 2011, 09:40:54 am
GEE-BEE
  • 1604
« Reply #10 on: August 21, 2011, 09:40:54 am »
I did a new booster, 22mm master
new s/s lines for 1991 cabby to fit the different master outlets ( location )
16v prop valves for the rear ( scirocco ) if you go disc
brakes are g60 corrado with bembo rotors
I have a new exta master if need be 22mm
and a set of new s/s front brake lines, I also have the rear s/s hardline
[email protected]
I got the seats and calipers and stuff for 400.00
I had to get the caliper adapters and e brake lines from [email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #11September 11, 2011, 01:59:49 am
moosiah
  • 106
« Reply #11 on: September 11, 2011, 01:59:49 am »
OK I did this too... I changed to 10.1 front disks and 200x40 rear drums and always had a squishy pedal  ( this might even still be the first post in this forum) Well I had to change the mstr cyl, so I got a booster frm a 90-something VW ( 9"?) and a 22 mm master cyl to match .. I had to dink with the push rod , but it was no big deal , just a little welding. just re-bent the lines to hook up to the rear wheel  proportioning  valves , same thread.. works great.. I was told it wouldn't work or was too hard ... don't believe it, If I can do it ,,, so can you ..
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #12September 15, 2011, 11:11:47 am
BigVWman
  • 332
« Reply #12 on: September 15, 2011, 11:11:47 am »
Not sure if helps much but if you want to try and get them to ship this fella has a truck booster and assorted other parts listed on local cl
http://raleigh.craigslist.org/pts/2570336943.html
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #13October 09, 2011, 03:39:08 pm
somolovitch3
  • 290
« Reply #13 on: October 09, 2011, 03:39:08 pm »
Jumping in a bit late...............................
'87 Rocco with the "V" looking MC w/4 ports and the proportioning valves screwed into it?
Is this a 22mm bore?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #14October 09, 2011, 03:57:52 pm
« Reply #14 on: October 09, 2011, 03:57:52 pm »
no..
its the same one as what came on base model golfs and jettas. 20mm, maybe even 19mm piston.
the master cylinders that had 2 ports, instead of 4 ports were the easiest to get upgrades for.. my 85 GTI had the 2 port MC, and i upgraded it to a mk3 21mm MC.. but my 86 Golf, it has a 4 port MC, with separate prop valves screwed into it..
the 4 port unit w/ prop valves WILL WORK with disk brakes tho. i have that particular setup. i favor the 2 port MC's better tho. less brake line clutter up around the MC.
