a wooden timing plug tool
Topic: a wooden timing plug tool (Read 2290 times)
August 04, 2011, 05:50:39 am
92EcoDiesel Jetta
August 04, 2011, 05:50:39 am »
Not sure if I posted this already. I couldn't find the black iron plumbing bushing which fits the timing mark plug and didn't want to run to the store to look for another so made one out of a wooden dowel. Took only minutes to make and works better than the bushing which needed a small pipe wrench to turn. With a long screwdriver you have a clear shot at the plug for easy removal.
I drew a 27 mm hex on the end of the dowel and used a knife for the hex and a saw for the slot.
August 04, 2011, 08:01:47 am
VWCaddy
Re: a wooden timing plug tool
August 04, 2011, 08:01:47 am »
I made a tool like that maybe 15 years ago and it worked fine. I think I still have it some place.
'82 VW pickup, 1.9D engine,
Missing LinkZ shift linkage
August 04, 2011, 08:45:55 pm
August 04, 2011, 08:45:55 pm »
I have 2 or 3 sockets that work.
August 06, 2011, 02:50:54 pm
regcheeseman
August 06, 2011, 02:50:54 pm »
I find a bolt with a head that fits the plug, and then lock two nuts on the other end to give you something to turn with.
August 07, 2011, 10:51:09 pm
southernman
August 07, 2011, 10:51:09 pm »
Hey guys, great idea to remove that plug !
I can't locate anyone that sells the plug and mine is missing. Everybody that has a spare trans doesn't want to part with theirs.
Any ideas where I can buy a replacement plug ?
D
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
