Author Topic: How do you remove the throttle thing on AAZ pump?  (Read 1889 times)
July 31, 2011, 02:15:12 pm
erice1984
  • 263
« on: July 31, 2011, 02:15:12 pm »
Here is the throttle springs and levers and whatnot.  How do I remove them to get the bolts out below it?
I already took the two torx screws out so the levers move independently of each other now
Probably have to remove that plastic bushing thing to get at the nut?  (I just realized this about a minute ago)
« Last Edit: July 31, 2011, 02:19:24 pm by erice1984 »
1980 Rabbit 1.9TD
Reply #1August 02, 2011, 08:57:42 pm
erice1984
  • 263
Re: How do you remove the throttle thing on AAZ pump?
« Reply #1 on: August 02, 2011, 08:57:42 pm »
I actually had to pry on it and go around in a circle to get the throttle piece to come up off the shaft. PITA
1980 Rabbit 1.9TD
