Author Topic: Fuel filter reccomendation to replace eco diesel filter?  (Read 2454 times)
July 26, 2011, 07:23:44 am
derekp
  • 94
« on: July 26, 2011, 07:23:44 am »
I'm looking for suggestions for a replacement fuel filter for my 92 eco-diesel.
I'd like to get away from the stock filter and its "heater" valve - to replace it with a less expensive spin on type filter.
I know I can bypass the "heater" thermostat in the return line with a piece of tubing and switch to the conventional filter - but the cost isnt a whole lot cheaper compared to a spin on filter.
I'm hoping to find something in the 5 micro or finer, that might fit where the original filter resides.
I've seen earlier rabbits had a spin on, I know remote filter adapters are available from numerous vendors, and I know fram makes a filter housing that takes a cartridge type filter (tho messy to change)
Anyone have any suggestions on this - I'd like to hear what you may have done.
thanks!
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #1July 26, 2011, 07:32:55 am
92EcoDiesel Jetta
Re: Fuel filter reccomendation to replace eco diesel filter?
« Reply #1 on: July 26, 2011, 07:32:55 am »
Check out Baldwin filter head BF1311 and BF948  8 micron spin on fuel filter (around $6 ea at Fleetpride).
Reply #2July 26, 2011, 02:48:28 pm
92EcoDiesel Jetta
« Reply #2 on: July 26, 2011, 02:48:28 pm »
The only thing with the BF1311 filter head is that it has an 2 female ORB ports and you have to find adapters to go to 5/16 fuel lines. A good hydraulic shop should have them.
Reply #3July 26, 2011, 03:06:28 pm
« Reply #3 on: July 26, 2011, 03:06:28 pm »
I like the stanadyne filters. They have a pile of extra add-ons like a heater, clear water bowl, lift pump, electric water sensor etc.
http://www.vwdiesel.net/forum/index.php?topic=14836.0
They are pretty easy to install, just be careful not to break off the plastic barbs on the FM10s. The FM100s are metal so no worries there
