Author Topic: Having a shop change my trans fluid?  (Read 7385 times)
Reply #15July 26, 2011, 12:20:30 pm
Re: Having a shop change my trans fluid?
« Reply #15 on: July 26, 2011, 12:20:30 pm »
pics or it didn't happen!
Reply #16July 27, 2011, 12:02:20 pm
« Reply #16 on: July 27, 2011, 12:02:20 pm »
Reply #17July 27, 2011, 01:11:51 pm
81 vw pu
« Reply #17 on: July 27, 2011, 01:11:51 pm »
Must of had tranny out of car to drain that way???
Reply #18July 27, 2011, 02:17:47 pm
« Reply #18 on: July 27, 2011, 02:17:47 pm »
Yeah I ended up taking it out anyway.. Had to do a clutch.. But I'd like to have it properly flushed and filled with better fluid.
Reply #19July 27, 2011, 02:35:22 pm
« Reply #19 on: July 27, 2011, 02:35:22 pm »
I don't think there is a more "proper" flush then out with the old, in with the new. I suppose you could change it again after a couple hundred kms if you were really ambitious.
Reply #20July 27, 2011, 02:39:52 pm
« Reply #20 on: July 27, 2011, 02:39:52 pm »
The only reason I even want to do that is because it sat for 5 years and then I drove it for a while and changed it when I had the trans out.. But the trans has well over 700k kms on it... So I was thinking an extra "flush" if you will would be a good thing.
Reply #21August 06, 2011, 01:36:25 pm
somedumbjerk
  • 71
« Reply #21 on: August 06, 2011, 01:36:25 pm »
Reply #22August 07, 2011, 09:08:03 am
« Reply #22 on: August 07, 2011, 09:08:03 am »
lol.. free if you can weld. or you can use a lug bolt and a wrench..
Reply #23August 08, 2011, 01:05:47 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #23 on: August 08, 2011, 01:05:47 pm »
I found after I was done that My dad had a welded tool, made from a nut and some flat steel, for his dune buggy.  Such is life :p
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
