General Information
General
Having a shop change my trans fluid?
Pages:
Topic: Having a shop change my trans fluid? (Read 7439 times)
Reply #15
July 26, 2011, 12:20:30 pm
Re: Having a shop change my trans fluid?
Reply #15 on:
July 26, 2011, 12:20:30 pm »
pics or it didn't happen!
Reply #16
July 27, 2011, 12:02:20 pm
Reply #16 on:
July 27, 2011, 12:02:20 pm »
Quote from: burn_your_money on July 26, 2011, 12:20:30 pm
x2
Reply #17
July 27, 2011, 01:11:51 pm
81 vw pu
Reply #17 on:
July 27, 2011, 01:11:51 pm »
Must of had tranny out of car to drain that way???
Reply #18
July 27, 2011, 02:17:47 pm
Reply #18 on:
July 27, 2011, 02:17:47 pm »
Yeah I ended up taking it out anyway.. Had to do a clutch.. But I'd like to have it properly flushed and filled with better fluid.
Reply #19
July 27, 2011, 02:35:22 pm
Reply #19 on:
July 27, 2011, 02:35:22 pm »
I don't think there is a more "proper" flush then out with the old, in with the new. I suppose you could change it again after a couple hundred kms if you were really ambitious.
Reply #20
July 27, 2011, 02:39:52 pm
Reply #20 on:
July 27, 2011, 02:39:52 pm »
The only reason I even want to do that is because it sat for 5 years and then I drove it for a while and changed it when I had the trans out.. But the trans has well over 700k kms on it... So I was thinking an extra "flush" if you will would be a good thing.
Reply #21
August 06, 2011, 01:36:25 pm
somedumbjerk
Reply #21 on:
August 06, 2011, 01:36:25 pm »
http://www.4crawler.com/Diesel/ForSale/DrainPlugTool.shtml
- the socket is only $8.
Reply #22
August 07, 2011, 09:08:03 am
Reply #22 on:
August 07, 2011, 09:08:03 am »
lol.. free if you can weld. or you can use a lug bolt and a wrench..
Reply #23
August 08, 2011, 01:05:47 pm
Grey_Smoke
fling wing for the win.
Reply #23 on:
August 08, 2011, 01:05:47 pm »
Quote from: R.O.R-2.0 on August 07, 2011, 09:08:03 am
I found after I was done that My dad had a welded tool, made from a nut and some flat steel, for his dune buggy. Such is life :p
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Pages:
General Information
General
