Author Topic: Injector Cleaning  (Read 5453 times)
July 18, 2011, 08:41:58 am
silentdub
  • 135
Injector Cleaning
« on: July 18, 2011, 08:41:58 am »
I'm tearing down my 1.6 and was wondering if you can just clean the injectors?
I am not used to these types of injectors, most gassers either work or don't work and you usually just toss them. These injectors are not electrical, so I am betting that they are open by pressure?
I'm not sure what to do here.
I searched and didn't find anything specific on cleaning them.
Reply #1July 18, 2011, 09:30:56 am
nathan_b
  • 361
Re: Injector Cleaning
« Reply #1 on: July 18, 2011, 09:30:56 am »
test, if worn out, rebuild 8)
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
Reply #2July 18, 2011, 09:35:40 am
silentdub
  • 135
« Reply #2 on: July 18, 2011, 09:35:40 am »
The injectors can be rebuilt? Parts? DIY? Kit?
Reply #3July 18, 2011, 10:50:26 am
southernman
  • 72
« Reply #3 on: July 18, 2011, 10:50:26 am »
Priior to determining if the injector can be cleaned, you need to take them to an injector shop, which has the tooling to test the injectors spray patterns - and to check for leaks (dripping post closure). Any shop that rebuilds injector pumps will have the equipment to test and rebuild injectors.
I had mine recently checked and only one had a good pattern and two dripped after they were closed. The latter might not seem like a bid deal at first, but if they drip when cold, they drip right on to the glow plug and will make your engine hard to start.
Any competent injector shop can test and rebuild your injectors. The key here is being able to test (visually verify) the injector spray patterns once rebuilt. My local shop charged me $150 to rebuild and test my injectors - plus, I've got a warranty in the event there's a problem. Also, don't forget to use new washers with your rebuilt injectors. The end result will have it purring like new and returning the fuel mileage we all value so highly.
Southernman
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
Reply #4July 18, 2011, 11:09:36 am
Mark(The Miser)UK
  • 1557
« Reply #4 on: July 18, 2011, 11:09:36 am »
Look up Hartridge. They sell diesel refurbishing tools. Easy to dismantleinjector and clean using Mr Muscle ovon cleaner, swill with diesel and reasemble. Buy a pressure tester...
Mark-The-Miser-UK
Reply #5July 18, 2011, 11:13:11 am
silentdub
  • 135
« Reply #5 on: July 18, 2011, 11:13:11 am »
Gotcha, Thanks!
The ones on the engine have 150K+ on them. I didn't know if there was a method to the madness or not.
I don't have any special tools for Injector pumps or injectors, so I may need to have someone do it.
Reply #6July 18, 2011, 09:28:41 pm
rabbitman
  • 2788
« Reply #6 on: July 18, 2011, 09:28:41 pm »
Gotcha, Thanks!
It's time for new or rebuilt ones.
Making a pop tester is lots of messing around and popping them is even more messing around so if you have more money than time and don't plan on ever doing a set again then you should have someone else do it.
Reply #7July 18, 2011, 11:47:41 pm
mystery3
  • 774
« Reply #7 on: July 18, 2011, 11:47:41 pm »
If your schedule allows I'd send them to Giles at Performance Diesel Injection for rebuild. I've bought rebuilt sets from reputable vendors and they've been less than perfect straight from the box.
Reply #8July 19, 2011, 12:42:19 am
Mark(The Miser)UK
  • 1557
« Reply #8 on: July 19, 2011, 12:42:19 am »
Gotcha, Thanks!
One thing you can do is check the injectors spray pattern by taking them out and reinstalling them on the fuel lines with the fuel lines 180 deg out ie upsidedown.
Put an old blanket under and get someone to turn engine over. Any poor nozzles will be easily seen. Bad ones can be cleaned with oven cleaner and bicycle spokes with end hammered and filed to a 60 deg point. Flush and reassemble and retest.
Mark-The-Miser-UK
Reply #9July 19, 2011, 07:16:27 am
silentdub
  • 135
« Reply #9 on: July 19, 2011, 07:16:27 am »
Not to sound like an ***, but why not just buy the rebuild parts and rebuild them regardless of testing?
Does anyone sell a rebuild kit?
Reply #10July 19, 2011, 07:52:04 am
92EcoDiesel Jetta
« Reply #10 on: July 19, 2011, 07:52:04 am »
Rebuilding injectors is replacing the worn nozzle with a new nozzle, cleaning setting opening pressure via shims and checking spray pattern and making sure no drips. Parts needed are new nozzles, various shims, new heat shields. The injector bodies are re-used. You can buy or make your onn tools to rebuild the injectors yourself. As far as nozzle goes, it will be very difficult to find German or French made Bosch nozzles (mayne NOS if you can find them), otherwise they will be from India, Brazil or wherever Bosch have them made these days. AFAIK, Monark nozzles are German made with an excellent reputation. I just bought a set and they're in the mail but my head gasket just blew while the nozzles are in transit.
Take a look at this link since you're new to diesels
http://www.vwdiesel.net/forum/index.php?topic=16687.0
Reply #11July 19, 2011, 08:03:36 am
Luckypabst
  • 502
« Reply #11 on: July 19, 2011, 08:03:36 am »
You need one of these, or some variant, to rebuild injectors:
 If you're only doing one set of four, you'll be ahead of the game to buy a rebuilt set. My experience is that Bosch rebuilts need to be rebuilt out of the box. Best to send your used injectors to a legit diesel shop and have them done by someone who cares.
Chris
'82 TD Westy
'81 NA Caddy
Reply #12July 19, 2011, 10:20:29 am
silentdub
  • 135
« Reply #12 on: July 19, 2011, 10:20:29 am »
Thanks guys, this may be my first Diesel of many, I'll send the pump and injectors out this time, if I get further in to it, then I will invest.
Thanks again for the quick responses!
Reply #13July 19, 2011, 08:08:53 pm
wdkingery
  • 494
« Reply #13 on: July 19, 2011, 08:08:53 pm »
Gotcha, Thanks!
this is the kind of info you need!
Reply #14July 19, 2011, 08:33:58 pm
rabbitman
  • 2788
« Reply #14 on: July 19, 2011, 08:33:58 pm »
One thing you can do is check the injectors spray pattern by taking them out and reinstalling them on the fuel lines with the fuel lines 180 deg out ie upsidedown.color]
The upper coolant hose gets in the way.
