Author Topic: oil cooler  (Read 9816 times)
July 17, 2011, 11:48:56 pm
grape ice cream
  • 70
oil cooler
« on: July 17, 2011, 11:48:56 pm »
hey all,
i have everything i need for the stock 1.6td oil cooler setup except for the metal coolant line
I was wondering if i should just get a front mounted "air cooled" radiator type oil cooler instead of going through with the stock one.  it seems to be more popular and idk if the metal line is expensive.
any advice is appreciated
thanks
Reply #1July 18, 2011, 06:13:06 am
Re: oil cooler
« Reply #1 on: July 18, 2011, 06:13:06 am »
http://www.vwdiesel.net/forum/index.php?topic=25435.0
That is what I have. The coolant pipes are still available from online places and maybe the dealer if you don't want to go this route. I think german auto has the coolant pipe. I went this way for one reason, I eliminated the stock oil cooler so I wouldn't get antifreeze in the oil if it failed.
Reply #2July 18, 2011, 08:28:23 am
Re: oil cooler
« Reply #2 on: July 18, 2011, 08:28:23 am »
my AHU coolent pipe was full of rust holes.. i disliked the $100+ on a new one so saved lots of coin by building it out of copper.. under $20 in elbows and pipe... will never rust so on.. so think about that as a viable option also..
Reply #3July 18, 2011, 09:32:16 am
grape ice cream
  • 70
Re: oil cooler
« Reply #3 on: July 18, 2011, 09:32:16 am »
Are you running both of those oil coolers at once?
Reply #4July 18, 2011, 10:35:38 am
Re: oil cooler
« Reply #4 on: July 18, 2011, 10:35:38 am »
hey all,
thanks
mk1 doesnt take a special metal coolant line.. its the rad bypass hose, and the 4" long connector hose that goes from the metal coolant pipe, to the center barb of the water pump.
Reply #5July 18, 2011, 11:29:54 am
rallydiesel
  • 1880
Re: oil cooler
« Reply #5 on: July 18, 2011, 11:29:54 am »
Is anybody on here using an a/c condensor as an oil cooler rad?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6July 18, 2011, 02:40:58 pm
Re: oil cooler
« Reply #6 on: July 18, 2011, 02:40:58 pm »
I am not using both coolers at once, Libbybapa is. He uses the stock as a warmer and the one linked as the cooler.
I used a a/c condensor in a bronco but never in a vw. That is a lot of cooling and in the winter around here I think it would be counter productive even with the thermo plate. It still lets 10% oil circulate so the engine isn't shocked by cold oil all the sudden. With something that big it might run cool all the time for our little engines.
Reply #7July 18, 2011, 04:02:49 pm
rallydiesel
  • 1880
Re: oil cooler
« Reply #7 on: July 18, 2011, 04:02:49 pm »
Yeah I think I will have to look for something smaller than the a/c condensor but I definitely need something. Unfortunately I have the added challenge of ridiculously cold winters and insanely hot summers in this god-forsaken place.
« Last Edit: July 18, 2011, 04:04:21 pm by rallydiesel »
Reply #8July 20, 2011, 11:07:59 am
grape ice cream
  • 70
Re: oil cooler
« Reply #8 on: July 20, 2011, 11:07:59 am »
Another question, this appears to be a mount of some sort but i'm unsure of where it actually goes, any help?
Reply #9July 20, 2011, 12:08:48 pm
rallydiesel
  • 1880
Re: oil cooler
« Reply #9 on: July 20, 2011, 12:08:48 pm »
That's the passenger side engine mount bracket.
Reply #10July 20, 2011, 12:11:47 pm
grape ice cream
  • 70
Re: oil cooler
« Reply #10 on: July 20, 2011, 12:11:47 pm »
So, since i already have a passenger engine mount i do not need this
Reply #11July 20, 2011, 01:32:28 pm
Re: oil cooler
« Reply #11 on: July 20, 2011, 01:32:28 pm »
That is the hard mount to the engine. It bolts to the rubber mount that is on the car. If you have a mount like this on the back of your engine then you don't need this one. If not you probably bought the rubber engine mount that goes in the car and you need both.
Reply #12July 21, 2011, 02:55:54 pm
grape ice cream
  • 70
Re: oil cooler
« Reply #12 on: July 21, 2011, 02:55:54 pm »
Alright, well I have a mk1 1.6Na that i'm converting so i'm assuming i do not already have on, so it bolts to a rubber mount in the back near the firewall?
Reply #13July 21, 2011, 03:13:38 pm
clarkrep
  • 117
Re: oil cooler
« Reply #13 on: July 21, 2011, 03:13:38 pm »
That's a mk2 rear passenger side mount. So, no you don't need it. It's nice and clean though... ;D
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #14July 21, 2011, 06:02:38 pm
grape ice cream
  • 70
Re: oil cooler
« Reply #14 on: July 21, 2011, 06:02:38 pm »
thank you, and yea if someone wants it feel free to contact me.
But back to my original question, i hooked up my oil cooler and connected the the "T" hose that goes from the water pump to the oil cooler and the little nipple piece.
The other hose goes from the oil cooler to where? I was under the impression it went into a fitting on the metal coolant line but there is none
