Author Topic: T3 Wastegate help- what's this second fitting for???  (Read 2884 times)
June 30, 2011, 08:59:46 pm
JGWarner
  • 77
« on: June 30, 2011, 08:59:46 pm »
Another conundrum courtesy of the Fox TD project:
I can't figure out what this second fitting on the wastegate of my Garrett T3 is for:
I attached the larger wastegate fitting to the right angled fitting on the pressure side of the turbo (green arrows). Duh.
But what attaches to the smaller fitting on the wastegate (red arrow)? Note the blue capped fitting on the vacuum side of the turbo inlet- was like that when I got it. I can't find any photos of when I removed the turbo, the manual is unclear or only shows a wastegate with one large fitting (a K24?).
« Last Edit: June 30, 2011, 09:09:00 pm by JGWarner »
Reply #1June 30, 2011, 09:11:55 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: T3 Wastegate help- what's this second fitting for???
« Reply #1 on: June 30, 2011, 09:11:55 pm »
it is likely for vacuum. AKA a gasser car application with a throttle body.
Reply #2June 30, 2011, 09:19:33 pm
JGWarner
  • 77
« Reply #2 on: June 30, 2011, 09:19:33 pm »
So... what do I connect it to? This turbo was (and is again) installed on a MD engine code TD motor.
Reply #3June 30, 2011, 09:23:25 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: June 30, 2011, 09:23:25 pm »
connect it to atmosphere.
Reply #4June 30, 2011, 09:36:54 pm
JGWarner
  • 77
« Reply #4 on: June 30, 2011, 09:36:54 pm »
...I'm gonna need a longer hose!
Reply #5July 01, 2011, 08:41:50 am
« Reply #5 on: July 01, 2011, 08:41:50 am »
you just connect it there where that blue cap is
Reply #6July 01, 2011, 10:33:29 am
« Reply #6 on: July 01, 2011, 10:33:29 am »
blue capped nipple... just filtered air...
Reply #7July 01, 2011, 11:59:50 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: July 01, 2011, 11:59:50 am »
Reply #8July 01, 2011, 07:33:53 pm
damac
  • 531
« Reply #8 on: July 01, 2011, 07:33:53 pm »
That looks different than the t3 on my 85 jetta?
But mine has those 2 connections on the turbo going to the wastegate.  I don't have a nipple in the casting, its just a hole with some rtv and a small hose mashed in there to fill up the room.  Then a metal piece that goes into that, then on the other end screws into the wastegate smaller line.
The bigger line goes from that barb on the turbo to a hose to a metal piece of line that has a flared threaded connection at the end that screws into the wastegate larger hole.
1985 turbo diesel jetta
Reply #9July 01, 2011, 08:33:06 pm
JGWarner
  • 77
« Reply #9 on: July 01, 2011, 08:33:06 pm »
This turbo came out of a VW Quantum TD.
