Author Topic: Need HELP fast!!!!  (Read 3296 times)
January 26, 2006, 03:41:03 pm
g-spec
  • 289
Need HELP fast!!!!
« on: January 26, 2006, 03:41:03 pm »
i did the governor mod today because i had the pump out......i didnt have the smallest spring...so i just removed the medium one with a little metal tube!!!! now the car idles...but does not rev at all!!!!! its seems to idle a little rough!!!!!
please help!!!!!!!!
thanks
Reply #1January 26, 2006, 03:56:59 pm
935racer
Need HELP fast!!!!
« Reply #1 on: January 26, 2006, 03:56:59 pm »
If it doesn't rev at all there are a couple possibilities. It is possible that the actual throttle shafts' splines are not engaged with the throttle lever. Or the the governor assembly is not hooked up to the lever assembly.
Reply #2January 27, 2006, 07:54:14 am
Dr. Diesel
  • 1341
Need HELP fast!!!!
« Reply #2 on: January 27, 2006, 07:54:14 am »
i second that motion.
and that the throttle shaft splines are not clocked right before putting the lever on.
Reply #3January 27, 2006, 04:07:47 pm
g-spec
  • 289
Need HELP fast!!!!
« Reply #3 on: January 27, 2006, 04:07:47 pm »
ok...so imoved the throttle lever about 3 splins.....everything works ok besides while driving the rpms will not drop...they just keep rising!!!!!!
what could that be???
Reply #4January 27, 2006, 04:22:44 pm
935racer
Need HELP fast!!!!
« Reply #4 on: January 27, 2006, 04:22:44 pm »
Oh man, that means your splines aren't in the right postition. Basically you are gonna need to keep playing with the splines until you get it back int he EXACT same spot it was when you took it apart, it is crucial that you mark the splines so you cna put them back in the exact same spot. Bummer dude hope you have some luck and get it back to the same spot.
Reply #5January 27, 2006, 04:25:06 pm
g-spec
  • 289
Need HELP fast!!!!
« Reply #5 on: January 27, 2006, 04:25:06 pm »
i had it in a good spot where it worked sweet....but the throttle would come on when the gas pedal was pushed in half way!!!!!!!
maybe there is something in the middle that i missed!!!! ill keep trying.....im getting better and better at this!!!!!!
Reply #6January 27, 2006, 04:31:00 pm
935racer
Need HELP fast!!!!
« Reply #6 on: January 27, 2006, 04:31:00 pm »
3 splines is a lot, once you get the splines out of wack its pretty tricky to find the right spot again. IF you get really close but the engine runs away once you get about half way through the rev range you are pretty close, and than you can just back the fuel screw otu and you should be good.
