Author Topic: Stiff/stuck cold start advance lever  (Read 5262 times)
June 29, 2011, 11:24:15 pm
JGWarner
  • 77
« on: June 29, 2011, 11:24:15 pm »
In the course of my Fox TD project I removed, cleaned, and re-installed the IP, all this time with a freely moving cold start advance arm/lever.
Then installed the cable to control it, still moved freely with the cable and by hand.
Then I timed the engine, set the lift timing on the pump (using the dial indicator method), turned it over a few revolutions in the course of setting all the timings, and now my cold advance lever is jammed in the off position. I can barely move it by hand, and the cable doesn't stand a chance of budging it.
What did I do?
Reply #1June 30, 2011, 05:48:56 am
Re: Stiff/stuck cold start advance lever
« Reply #1 on: June 30, 2011, 05:48:56 am »
try and start it. Mine feels like the cable is going to break if I pull it and it isn't running or cranking. Might be all that it is since it is in a new spot???
Reply #2June 30, 2011, 09:34:38 am
« Reply #2 on: June 30, 2011, 09:34:38 am »
if the cam plate is getting ready to travel UP the rollers, then you have the spring force from the plunger, trying to push the cam plate back down the rollers, but then you activate the cold start advance, and it moves the rollers a little farther up the cam plate bumps.
Reply #3June 30, 2011, 01:19:27 pm
« Reply #3 on: June 30, 2011, 01:19:27 pm »
Yes either start it, or turn the motor another 1/4 turn by hand. See if that helps.
Reply #4June 30, 2011, 01:21:28 pm
JGWarner
  • 77
« Reply #4 on: June 30, 2011, 01:21:28 pm »
Thanks guys, I'll try that tonight. Definitely feels like I'm fighting the tension of the timing belt/motor. I guess I was freaking out for no reason!
Reply #5June 30, 2011, 01:27:36 pm
« Reply #5 on: June 30, 2011, 01:27:36 pm »
if the cold start advance is hard to pull when before i start my car, i put a little tension on the cold start knob, hit the key, then i pull the cold start as the engine is turning over, and then the knob pretty much flies out..
Reply #6July 01, 2011, 08:06:37 pm
damac
  • 531
« Reply #6 on: July 01, 2011, 08:06:37 pm »
If we are not talking about binding up inside the pump, I stumbled on something on another forum as far as the cable routing goes.   If you don't route that thing right it can tweak enough to get stuck, etc.
For me the missing link was some small vw bushings that go around that piece in the arm that you screw the cable down to!  It makes it so it tracks correctly and doesn't go cockeyed, etc.  My pumps never had any on there so it was amazing to get the new ones and set the cable and tighten down and have it work the first time!  Not tracking straight would allow the slack to hit things.
1985 turbo diesel jetta
Reply #7July 01, 2011, 08:30:57 pm
JGWarner
  • 77
« Reply #7 on: July 01, 2011, 08:30:57 pm »
Part numbers please!
I did think it was odd how that little metal cylinder just floated around loose in the lever.
Reply #8July 02, 2011, 11:25:44 am
« Reply #8 on: July 02, 2011, 11:25:44 am »
are you talking about the bushing for the cable bracket? or for the cable connection at the end of the actual arm?
Reply #9July 02, 2011, 06:19:59 pm
damac
  • 531
« Reply #9 on: July 02, 2011, 06:19:59 pm »
Here is the vw part # 068-130-337
Here is a pic from another thread
Reply #10July 02, 2011, 07:14:52 pm
JGWarner
  • 77
« Reply #10 on: July 02, 2011, 07:14:52 pm »
thank you!
Reply #11July 02, 2011, 09:05:33 pm
  • 4553
« Reply #11 on: July 02, 2011, 09:05:33 pm »
I had those washer/ bushings crack on me and I found some very close in diameter at the hardware store.  Only needed a little filing with a fine toothed file to make them work. Outside diameter was spot on.  Lever works flawlessly now.
Reply #12July 03, 2011, 08:11:32 am
« Reply #12 on: July 03, 2011, 08:11:32 am »
HOLY CRAP!! ive never seen those before! none of my pumps have those..
Reply #13July 03, 2011, 11:04:33 pm
RadoTD
  • 513
    Stage WTF
« Reply #13 on: July 03, 2011, 11:04:33 pm »
My pump's got the same cold advance as that.... right under the idle adjustment. Where's the lever on your pumps for cold start advance?
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #14July 04, 2011, 07:56:07 am
« Reply #14 on: July 04, 2011, 07:56:07 am »
the bushings, not the cold start lever..
