Author Topic: needed: various ID's of hoses  (Read 2088 times)
June 22, 2011, 02:34:09 pm
somedumbjerk
  • 71
« on: June 22, 2011, 02:34:09 pm »
honestly I tried searching, and couldn't come up with it. Is there a standard ID for the tube to the wastegate and the tube from the LDA to the intake? I'm trying to plumb out the boost controller and gauge and I'm a little hesitant to cut it open to bring it to the hardware store that barely has anything in stock. My girlfriend will kill me if I render this car undrivable one more time.
thanks!
Reply #1June 22, 2011, 05:08:43 pm
Thezorn
  • 381
Re: needed: various ID's of hoses
« Reply #1 on: June 22, 2011, 05:08:43 pm »
1/8th inside diameter will work fine, I used high temp silcone hose since I got it for free from my job a while back
Compounded 93 AAZ
Reply #2June 22, 2011, 05:12:59 pm
somedumbjerk
  • 71
« Reply #2 on: June 22, 2011, 05:12:59 pm »
1/8th for the LDA?
Reply #3June 24, 2011, 05:50:25 pm
Thezorn
  • 381
« Reply #3 on: June 24, 2011, 05:50:25 pm »
for LDA and the wasteagte also
Compounded 93 AAZ
Reply #4June 24, 2011, 08:05:54 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #4 on: June 24, 2011, 08:05:54 pm »
3.5mm. use silicone if you can. if you are using silicone, go with 3mm as the silicone gets a little stretchy over time.
Reply #5June 24, 2011, 08:21:55 pm
somedumbjerk
  • 71
« Reply #5 on: June 24, 2011, 08:21:55 pm »
Thank you very much!
Reply #6July 19, 2011, 08:37:22 am
somedumbjerk
  • 71
« Reply #6 on: July 19, 2011, 08:37:22 am »
the hose to the wastegate is closer to 3/8" it looks like. the damn boost controller i bought off ebay has 1/4" barbs. anyone got a pic of what they did to get the boost controller to fit on the t3? cut the metal line? or the rubber? or just build a boost controller with the right barbs... heh....
