Author Topic: 1.8 gas manifold  (Read 3138 times)
June 19, 2011, 12:03:14 pm
fdnyguy
  • 499
1.8 gas manifold
« on: June 19, 2011, 12:03:14 pm »
Recently received a 1.8 gas  exhaust manifold for my 1.6 NA. Will post part number later on for you guys to verify.
With a Giles IP, should I/could I port and polish this for a freer flowing exhaust?
I did get this from a machinist in my VW club, he mentioned to get him a gasket before he does the work.
If I am wrong on his info above, as usual your help is needed. I was going to buy it from TT with the d/p, but hopefully he saved me a few $$.
Advice and help is as usual, appreciated.
Stay safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #1June 19, 2011, 12:52:12 pm
Re: 1.8 gas manifold
« Reply #1 on: June 19, 2011, 12:52:12 pm »
Well any 8v exhaust manifold will fit for sure.. So your good there.
I am not entirely sure it is any better than the stock manifold? Are you using this as an upgrade? Or because you just needed a manifold?
I think when porting and gasket matching, the head will need work too... Or there will be steps in the exhaust flow for turbulence to happen..
Reply #2June 19, 2011, 02:13:56 pm
fdnyguy
  • 499
« Reply #2 on: June 19, 2011, 02:13:56 pm »
I was told that a 1.8 manifold would give a better performance with a Giles modified IP. I was going to order one with a flex D/P from Techtronics and go with a 2.25" exhaust.
I was just curious if porting the manifold would be any better. As you can see with my limited mechanical knowledge, I did not think about the head. :)
So if so, I will have to do both instead of just one.
Many thanks for the reply.
Reply #3June 19, 2011, 04:19:14 pm
« Reply #3 on: June 19, 2011, 04:19:14 pm »
theres like 4 different kinds of manifolds tho..
single bolt on downpipe
dual bolt on downpipe (big flange)     <---this is the only one you get any gains from
dual bolt on downpipe (small flange)
toilet bowl type
so, witch is it?
Reply #4June 19, 2011, 05:52:58 pm
« Reply #4 on: June 19, 2011, 05:52:58 pm »
and i believe the diesel toilet bowl was actually larger, the one on my car doesn't look very restrictive anyway, a bigger down pipe would definitely give some awesome flow, as much as any 1.6d non turbo would ever need
Reply #5June 19, 2011, 06:28:18 pm
« Reply #5 on: June 19, 2011, 06:28:18 pm »
toilet bowl type
so, witch is it?
I was unaware that there were 2 styles of the dual styles. When did they make the switch?
Porting the manifold would be costly and very labour intensive with minimal gain.
Is this the small one? As in the mk1 version?
https://lh4.googleusercontent.com/--lY3FikZOCs/Tf5-QS-Ax8I/AAAAAAAAAEU/SNavCJXc5Vk/s912/100_1007.JPG
« Last Edit: June 19, 2011, 06:29:54 pm by burn_your_money »
Reply #6June 19, 2011, 07:10:06 pm
fdnyguy
  • 499
« Reply #6 on: June 19, 2011, 07:10:06 pm »
Thanks, guys. FWIW, it has 6 bolts on the D/P side, which I am sure most do. :)
From what I could gather, part number is 055 253 033.
I was just questioning myself and wondering since the 1.8 from TT doesn't need it, would it be worth it to do it to this one, even if the guy who gave it to me was giving me a good price to do it?
Thanks for the heads up, Tyler.
Thanks to everyone else as well. I stay amazed and in awe at what you guys do with these VW diesels. :)
ROR, do you have the part number for the big flange you mention?
« Last Edit: June 19, 2011, 07:16:43 pm by fdnyguy »
Reply #7June 20, 2011, 10:54:27 am
« Reply #7 on: June 20, 2011, 10:54:27 am »
toilet bowl type
so, witch is it?
yes, mk1 dual..
Reply #8June 20, 2011, 10:56:02 am
« Reply #8 on: June 20, 2011, 10:56:02 am »
no idea what the part number is, i would have to take it off my wrecked mk2 to even find it..
manifold is off an 88 Jetta.. PF code engine.. downpipe is off a 92 jetta 16v..
