Author Topic: The Mule  (Read 12480 times)
May 04, 2011, 08:37:52 pm
rwdriver
  • 107
The Mule
« on: May 04, 2011, 08:37:52 pm »
it started out life as an 84 jetta diesel with a rear axle being held on by a cable
then had an encounter with a sawzall
then had a third leg installed
some finishing touches, and the mule is born complete with am/fm radio, static throttle(cruise control), chalkboard hood, and a 1200 watt power inverter is soon to be installed
The Mule: small and ugly, but strong
Governor modded,fuel screw turned WAY in, and intake modded. it RIPS!
Reply #1May 04, 2011, 08:53:05 pm
wdkingery
  • 494
Re: The Mule
« Reply #1 on: May 04, 2011, 08:53:05 pm »
ooo that poor jetta!!
dude i bet that thing is dangerous at speed. i bet it does all you need it to tho
Reply #2May 04, 2011, 09:02:02 pm
trav1856
  • 230
Re: The Mule
« Reply #2 on: May 04, 2011, 09:02:02 pm »
That's what I need to do with my cabriolet lol
1981 Rabbit Diesel
1981 Cabriolet
Reply #3May 04, 2011, 09:33:46 pm
  • 1739
Re: The Mule
« Reply #3 on: May 04, 2011, 09:33:46 pm »
You HAVE to get videos up
Reply #4May 04, 2011, 11:55:29 pm
Re: The Mule
« Reply #4 on: May 04, 2011, 11:55:29 pm »
Epic ;D
are you going to spring for some suspension at the 3rd wheel?
Also a motorcycle sprocket on a starter motor might be cool if you find yourself getting stuck.
Reply #5May 05, 2011, 12:59:18 am
keaton
  • 90
Re: The Mule
« Reply #5 on: May 05, 2011, 12:59:18 am »
might wanna add a roll hoop.....
2006 1.9L BRM 5-speed Manual... 100% Stock :(
Standalone VGT/VNT controller: http://dmn.kuulalaakeri.org/vnt-lda/
My CAN Bus video recorder: http://www.youtube.com/watch?v=2QuRBQzGs-c
Reply #6May 05, 2011, 01:40:36 am
maxfax
  • 2126
Re: The Mule
« Reply #6 on: May 05, 2011, 01:40:36 am »
Very cool!!   You need a brake on that back wheel for snow!
Reply #7May 05, 2011, 06:18:16 am
DJPyro
  • 66
Re: The Mule
« Reply #7 on: May 05, 2011, 06:18:16 am »
Awesome, and I need to find one of those Jetta Diesel badges for the back of my MK3.
Reply #8May 05, 2011, 07:59:39 am
trav1856
  • 230
Re: The Mule
« Reply #8 on: May 05, 2011, 07:59:39 am »
Yeah and you could do like a motorcycle wheel and have a dual caliper setup, so you don't have to plug up anything on the master cylinder, just use it as-is
1981 Rabbit Diesel
1981 Cabriolet
Reply #9May 05, 2011, 08:46:15 am
rwdriver
  • 107
Re: The Mule
« Reply #9 on: May 05, 2011, 08:46:15 am »
It drives kinda funny. all the weight is over the front wheels, so it wont fishtail. you can pick uip the back end with one hand, so you have to go easy on the brakes or itèll tip over
Reply #10May 05, 2011, 08:53:15 am
trav1856
  • 230
Re: The Mule
« Reply #10 on: May 05, 2011, 08:53:15 am »
so ya need a wheelie bar.....on the front haha
Might need some more utensils on the back...maybe even a 3pt hitch hehe
1981 Rabbit Diesel
1981 Cabriolet
Reply #11May 05, 2011, 09:42:44 am
rwdriver
  • 107
Re: The Mule
« Reply #11 on: May 05, 2011, 09:42:44 am »
Reply #12May 05, 2011, 11:03:38 am
wdkingery
  • 494
Re: The Mule
« Reply #12 on: May 05, 2011, 11:03:38 am »
hahaha that thing jumps from a stop with no weight on it! you didn't lose hardly any RPM when you took off
Reply #13May 05, 2011, 11:39:28 am
Quantum TD
  • 1195
Re: The Mule
« Reply #13 on: May 05, 2011, 11:39:28 am »
So what is the functional purpose of this thing?
Reply #14May 05, 2011, 02:15:46 pm
rwdriver
  • 107
Re: The Mule
« Reply #14 on: May 05, 2011, 02:15:46 pm »
I use it around the farm, for towing things, transportation, power and sound
