Author Topic: The Mule  (Read 12352 times)
Reply #45July 12, 2011, 10:11:38 pm
rwdriver
  • 107
Re: The Mule
« Reply #45 on: July 12, 2011, 10:11:38 pm »
Yeah, I really want to do rear steering, but there's no way to do it without running a crazy small tire, or hacking up the frame.
Tempting....
http://tinyurl.com/5ullw7l
Oh, and I was fiddling with the wastegate on the k14 today, and I found that with the wastegate completely disconnected, the boost peaks at about 18psi. is this normal?
Reply #46July 15, 2011, 07:31:42 pm
rwdriver
  • 107
Re: The Mule
« Reply #46 on: July 15, 2011, 07:31:42 pm »
Does anyone know where I could find a heavier flywheel?
Reply #47July 15, 2011, 09:34:42 pm
Re: The Mule
« Reply #47 on: July 15, 2011, 09:34:42 pm »
a stock 1.9 diesel would be heavier as it is bigger...210mm
a 1.8 gasser maybe the same or similar weight. All you need to do is swap all the parts over. 18psi not intercooled is a bit much for that turbo I think.
Reply #48July 16, 2011, 11:20:18 am
Re: The Mule
« Reply #48 on: July 16, 2011, 11:20:18 am »
ABAs got heavy flywheels, along with AAZs
1.8 flywheels are lighter than diesel flywheels..
gasser flywheels are lightest, then comes stock diesel wheels, then the heaviest ones are off the 1.9 and 2.0..
