Author Topic: need some franken parts and advice  (Read 2522 times)
April 15, 2011, 08:44:48 pm
mean88
  • 38
« on: April 15, 2011, 08:44:48 pm »
I need a part number and place to order a good 1 notch head gasket.  I would also like to know what head studs to order and where as I dont want to use the stock bolts.  I am building a 1.6 HYD with a 1.9 HYD head on it. I am also adding a t3 turbo.  The pump is stock, just rebuilt with new injectors.  I was also wondering what the timing should be, I ve read as much as 1.25mm for extra advance.  Suggestions?  Thanks
Ted
Reply #1April 15, 2011, 08:57:58 pm
nathan_b
  • 361
Re: need some franken parts and advice
« Reply #1 on: April 15, 2011, 08:57:58 pm »
I used a 2 notch head gasket. I played with timing for a long time until I settled on 1.00
With a aaz k14 an intercooler running 17lbs of boost, gov mod and pump tuning, I can do a 0-60 run in 9.5s and not be above 875f egts. Cruising at 60-65mph is 500-600 on flat, no higher than 750f on the steepest highway grade going 60mph. Hard to get it above 950f period. Now I am worried about slipping the clutch, it has a 16v clutch, but rolling in 2nd if I lay into it it will break the tires free. It pulls so hard in 4th that it hurts my neck if I do it a few times.
intercooling is what turned my motor from pretty good, to holy crap.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
Reply #2April 15, 2011, 08:58:46 pm
nathan_b
  • 361
« Reply #2 on: April 15, 2011, 08:58:46 pm »
1 hole (1.53mm) 028 103 383BH
2 hole (1.57mm) 028 103 383BJ
3 hole (1.61mm) 028 103 383BK
world impex has them I believe
Reply #3April 15, 2011, 11:43:31 pm
Baron VonZeppelin
« Reply #3 on: April 15, 2011, 11:43:31 pm »
Lucky day if you act fast.
Only ONE left in stock - www.rockauto.com has them on closeout sale. One Notch - Beck/Arnley
$3.06    :o
http://www.rockauto.com/catalog/x,carcode,1282799,parttype,5412
If that link doesn't work - go to their website and use 85 jetta TboDzl as car input criteria. I was roaming through there the other night and spotted this deal.
Good Luck
« Last Edit: April 15, 2011, 11:46:57 pm by Baron VonZeppelin »
Reply #4April 16, 2011, 06:42:32 am
mean88
  • 38
« Reply #4 on: April 16, 2011, 06:42:32 am »
any advice on head studs?
Reply #5April 16, 2011, 07:08:56 am
« Reply #5 on: April 16, 2011, 07:08:56 am »
ARP has ones that are made for the TDI now.
We used to use the ARP that is listed in the FAQ with the title ARP part #
Reply #6April 16, 2011, 09:43:27 am
rallydiesel
  • 1880
« Reply #6 on: April 16, 2011, 09:43:27 am »
I would start off timing it at the normal 1.00mm. From here all you can really do is time it by ear/performance. It will need to be advanced until it stops missing at idle and the smoke clears up but stop before the clattering gets worse. It's a trial and error thing when you are building a hybrid engine.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7April 16, 2011, 11:40:32 am
Baron VonZeppelin
« Reply #7 on: April 16, 2011, 11:40:32 am »
BTW - the gasket i linked is the fiber style 1.6 (stock).
Happened to wonder if you were actually wanting a 1.9 Multi Layer Steel head gasket.
The fiber with studs - supposed to be good to about 20-25 psi boost.
The MLS goes up to higher psi boost.
But requires very strait deck and head tolerances.
fwiw
Reply #8April 18, 2011, 09:52:57 pm
Baron VonZeppelin
« Reply #8 on: April 18, 2011, 09:52:57 pm »
and oh yeh
i farked up and overlooked you said HYD.
the gasket i linked is Mech.
sorry
