Author Topic: dimensions of the governor  (Read 2903 times)
April 09, 2011, 01:41:53 am
adi
« on: April 09, 2011, 01:41:53 am »
Does anyone have a governor out of a pump that they could measure for me? I need to get hold of some shimming steel/washers before I take it out and shim it, but I need to know the diameter of the pin through the middle and the external diameter of the main spring. Thankyou in advance  ;D
Reply #1April 09, 2011, 01:46:04 am
Re: dimensions of the governor
« Reply #1 on: April 09, 2011, 01:46:04 am »
i use stainless nuts. not shims. its easy that way, just take a small nut that slips over the shaft, and use that. usually you want like 3-4mm of shims, IIRC
Reply #2April 09, 2011, 06:36:15 am
NA diesel
  • 8
« Reply #2 on: April 09, 2011, 06:36:15 am »
What size nuts do you use? Thread size and outer dimension would be helpful, then the OP could get what he or she needs before disassembling his or her pump.
I would be interested as well.  Either would be a hassle; taking my pump apart twice, or trying to get stainless hardware w/o my car being drivable.
« Last Edit: April 09, 2011, 06:38:47 am by NA diesel »
Reply #3April 09, 2011, 11:57:16 am
« Reply #3 on: April 09, 2011, 11:57:16 am »
sorry, i dont have an easy way to measure. dont wanna open up my pumps again..
if the nut is too big tho, it wont fit. lol.
nobody told me exactly what nut to use, i had to figure it out, so it shouldnt be too hard for someone else to figure it out either.
Reply #4April 09, 2011, 05:37:36 pm
« Reply #4 on: April 09, 2011, 05:37:36 pm »
Either #8 or #10 sae washers should do.
Reply #5April 09, 2011, 05:49:10 pm
81 vw pu
« Reply #5 on: April 09, 2011, 05:49:10 pm »
I have one out of a 1.6 na pump.
Rod od is 5/32
Spring od is 23/64
Reply #6April 10, 2011, 09:10:25 am
« Reply #6 on: April 10, 2011, 09:10:25 am »
i think i used 2 #8 stainless nuts in one pump, and 1 #10 in my other pump..
Reply #7April 11, 2011, 01:07:29 am
Alcaid
  • 549
« Reply #7 on: April 11, 2011, 01:07:29 am »
Rod od is 5/32
Spring od is 23/64
Could you measure cage ID as well? ;)
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound ;)
Reply #8April 11, 2011, 04:18:33 am
81 vw pu
« Reply #8 on: April 11, 2011, 04:18:33 am »
Rod od is 5/32
Spring od is 23/64
Not sure what the cage is?
Reply #9April 11, 2011, 04:22:22 am
Alcaid
  • 549
« Reply #9 on: April 11, 2011, 04:22:22 am »
The surrounding "frame" around the springs, what's the ID where the main spring sits? (which gives a max OD limit for the shims/nut)
