Author Topic: FS 0.5mm (0.020") Oversize Pistons  (Read 5535 times)
April 07, 2011, 07:35:52 pm
abnkeis
« on: April 07, 2011, 07:35:52 pm »
****SOLD***I have a set of 4 brand new pistons - 1.6 TD Kolbenschmidt 0.5mm (0.020") over $ 320****SOLD*****
I also have a TD block that has been cleaned and bored for 2nd oversize pistons if interested.
« Last Edit: May 13, 2011, 08:31:36 pm by abnkeis »
Reply #1April 08, 2011, 08:16:07 am
Re: FS 2nd Oversize Pistons
« Reply #1 on: April 08, 2011, 08:16:07 am »
these are 1st over size..
2nd oversize is +1mm
Reply #2April 08, 2011, 08:23:44 am
abnkeis
« Reply #2 on: April 08, 2011, 08:23:44 am »
I believe the book calls them second oversize, but yes it is the first size over stock. Sorry for the confusion.
Reply #3April 08, 2011, 08:34:41 am
Re: FS .20 Oversize Pistons
« Reply #3 on: April 08, 2011, 08:34:41 am »
well, there are no smaller oversize pistons, so i would call them 1st o/s atleast..
idk, there might be a .25mm o/s piston, but i doubt it.
Reply #4April 08, 2011, 08:44:58 pm
79rabbit4dr
« Reply #4 on: April 08, 2011, 08:44:58 pm »
.020" - twenty thousandths of an inch...
right?
or are there really .20" over-sized pistons around?
Reply #5April 08, 2011, 08:53:24 pm
abnkeis
« Reply #5 on: April 08, 2011, 08:53:24 pm »
Yes these are .020 over, sorry I guess I need to work on my proof reading skills.
Reply #6April 09, 2011, 12:25:52 pm
« Reply #6 on: April 09, 2011, 12:25:52 pm »
The OP is correct.  Those are 2nd oversize.  1st oversize is .010" over or 76.73(4,5).  R.O.R. you are also kinda sorta correct as the .010" oversize pistons are not available as far as I know.  It is my understanding that they were used for early factory "remanufactured" engines and presumably used to correct flaws in the original engine manufacture that were minor enough to correct by boring slightly larger.
wow, gotta have a pretty decent bore to have a .010" overbore clean it up.. then again, ive never seen .010" over pistons either..
Reply #7April 23, 2011, 09:23:53 am
abnkeis
Re: FS 0.5mm (0.020") Oversize Pistons
« Reply #7 on: April 23, 2011, 09:23:53 am »
Need these gone!!!
Reply #8May 09, 2011, 07:23:56 pm
abnkeis
« Reply #8 on: May 09, 2011, 07:23:56 pm »
Still Available!!!
Reply #9May 12, 2011, 07:23:03 pm
b13bliss
« Reply #9 on: May 12, 2011, 07:23:03 pm »
If these include the rings, I'll take them.  Let me know.  thanks!
Reply #10May 12, 2011, 08:21:59 pm
abnkeis
« Reply #10 on: May 12, 2011, 08:21:59 pm »
They do have rings, so if you want them they are yours!!!
Reply #11May 15, 2011, 11:13:06 am
sootyperry
  • 20
« Reply #11 on: May 15, 2011, 11:13:06 am »
how much for the td block? with pistons and squirters?
Reply #12May 15, 2011, 05:11:15 pm
abnkeis
« Reply #12 on: May 15, 2011, 05:11:15 pm »
The pistons are sold sorry. I am open to any reasonable offers on the block.
