Author Topic: Circlips on the governor assembly  (Read 6985 times)
March 29, 2011, 09:10:48 am
« on: March 29, 2011, 09:10:48 am »
Does Volkswagen still stock the little circlips for the governor mod assembly?  ;D I was trying something, and ZING goes one of the little circlips.. It hit me, i saw it fall, but its gone forever... :P
lol
Reply #1March 29, 2011, 10:57:08 am
Re: Circlips on the governor assembly
« Reply #1 on: March 29, 2011, 10:57:08 am »
whatever section of the governor that clip was in, will no longer work.. those clips are what separate the different sections of governor..
Reply #2March 29, 2011, 11:48:26 am
« Reply #2 on: March 29, 2011, 11:48:26 am »
Thanks tips ;)
Lmao do you know where I can get some??
This was on a junk pump, was just trying something. When I get this correct, I will probably just swap the gov in to my running engine. Instead of mess with another gov.
Reply #3March 29, 2011, 12:01:17 pm
« Reply #3 on: March 29, 2011, 12:01:17 pm »
i got a half dozen clips laying around.. whole lot of good that does you tho..
Reply #4March 29, 2011, 12:19:17 pm
« Reply #4 on: March 29, 2011, 12:19:17 pm »
I suppose I could use a clip from the gov that this modded one will be replacing? Anything different between an 81 and 91 pump, internally? Like the circlips they should be the same yes?
Reply #5March 29, 2011, 12:24:40 pm
« Reply #5 on: March 29, 2011, 12:24:40 pm »
all the pumps i have parts from, or have laid hands on, are all old pumps..
Reply #6March 30, 2011, 04:09:19 pm
« Reply #6 on: March 30, 2011, 04:09:19 pm »
Here comes trouble....
Reply #7March 30, 2011, 04:45:48 pm
macka
  • 957
« Reply #7 on: March 30, 2011, 04:45:48 pm »
Didja try TSC they have an assload of jeebus clips
Quote from: Vincent Walden
Reply #8March 30, 2011, 05:06:11 pm
maxfax
  • 2126
« Reply #8 on: March 30, 2011, 05:06:11 pm »
Aren't they just an E-clip??  Just realized it's been years since I've had a pump apart, old age makes it hard to recall... ;)
Reply #9March 30, 2011, 06:05:56 pm
« Reply #9 on: March 30, 2011, 06:05:56 pm »
TSC! never even thought of them. (what is TSC? lol) I do suppose they are just a run of the mill e clip, I will just take one off the gov in the running pump.
Reply #10March 31, 2011, 01:24:09 am
maxfax
  • 2126
« Reply #10 on: March 31, 2011, 01:24:09 am »
Here it's Tractor Supply Company..  Fun place to shop!!!  I have to limit my time there though...
Reply #11March 31, 2011, 03:17:19 am
macka
  • 957
« Reply #11 on: March 31, 2011, 03:17:19 am »
Same as up here, where else can you get a cattle prod, bailing wire and diesel parts?  8)
Reply #12March 31, 2011, 05:10:17 am
maxfax
  • 2126
« Reply #12 on: March 31, 2011, 05:10:17 am »
 AND maple nut goodies in the check out line...  ;D  I love that place...
Reply #13March 31, 2011, 06:59:04 am
« Reply #13 on: March 31, 2011, 06:59:04 am »
Check with a place that services snowmobile's.
That clip is about the same as the clips that hold the needle in the carbs on snow machines.
Reply #14April 01, 2011, 07:32:12 am
« Reply #14 on: April 01, 2011, 07:32:12 am »
correct you are, that little clip is pretty close to the clip that holds the needles in bike/snowmobile carbs..
