Author Topic: Was reading that some were looking for good valves.  (Read 2641 times)
March 25, 2011, 05:41:31 pm
BillyWillicker
  • 111
« on: March 25, 2011, 05:41:31 pm »
I saw here that some of you were looking for nice valves for mechanical heads for thier high power IDI's.  I found the perfect items.  Being an audi guy I tripped over these.
http://www.034motorsport.com/engine-components-audi-i5-10vturbo-exhaust-valve-set-wx-urq-34mm-nitrided-stainless-with-install-parts-p-18555.html
http://www.034motorsport.com/engine-components-audi-i5-10vturbo-intake-valve-set-wx-urq-40mm-nitride-stainless-with-install-parts-p-18853.html
The intakes may be a bit too big, but the inconel exhausts should drop into a stock seat!  This is a SUPER deal at the price thier offered with what they come with.
Hope this helps out!
Oh, and what are the stock valve diameters in a 1.6 IDI mechanical engine?
« Last Edit: March 25, 2011, 05:52:07 pm by BillyWillicker »
Reply #1March 25, 2011, 05:54:14 pm
  • 5104
Re: Was reading that some were looking for good valves.
« Reply #1 on: March 25, 2011, 05:54:14 pm »
i believe the stem length is different on those
Reply #2March 25, 2011, 05:56:12 pm
BillyWillicker
  • 111
« Reply #2 on: March 25, 2011, 05:56:12 pm »
pretty sure its not, however it may be different.
Reply #3March 25, 2011, 09:37:16 pm
rabbitman
  • 2788
« Reply #3 on: March 25, 2011, 09:37:16 pm »
Stock 1.6D valves are 34mm intake and 31mm exhaust with 8mm stems.
Reply #4March 26, 2011, 04:01:36 pm
rabbid79
  • 684
« Reply #4 on: March 26, 2011, 04:01:36 pm »
This is 100% correct.  The diesel valves are ~105mm in length.  The gasser valves are ~91mm in length.  Part of this has to do with the head of the diesel being flat, so the valve has to be longer.  On the gas engines, with part of the combustion chamber in the head, they're shorter.
'15 WRX
Reply #5March 26, 2011, 04:40:02 pm
  • 5104
« Reply #5 on: March 26, 2011, 04:40:02 pm »
also solid lifter and hydro lifter have different length valves
