Author Topic: G60/MK3 8v Alloy rocker cover  (Read 8950 times)
January 17, 2006, 06:38:11 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« on: January 17, 2006, 06:38:11 am »
I want to fit a g60/mk3 alloy rocker cover to my SB engined MK2 GTD
Which one will fit?
My engine bay, with IC removed
I want to fit one of these and just polish the VW badge.
G60 PG engine with round pcv valve
G60 PG engine with square pcv valve
MK3 2.0 8V engine with square pcv and oil filler the opposite way round
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #1January 17, 2006, 10:11:49 am
jwspin
  • 138
« Reply #1 on: January 17, 2006, 10:11:49 am »
i was thinking of doing the same thing. anyone know if they will fit?
-jared
Reply #2January 17, 2006, 01:24:01 pm
Master ACiD
  • 328
« Reply #2 on: January 17, 2006, 01:24:01 pm »
my dad tested one on his 1.6td. t fits but you run into some issues of the gasket. i think you need to make a new gasket by hand, or use some special custom studs or something. cant rmemeber exactly what he eid, but its fits.
Reply #3January 17, 2006, 04:02:16 pm
jwspin
  • 138
« Reply #3 on: January 17, 2006, 04:02:16 pm »
prob need one of the updated ones. like the second one down here
http://www.germanautoparts.com/Volkswagen/Jetta/Engine/102/3
-jared
Reply #4January 17, 2006, 06:05:44 pm
935racer
« Reply #4 on: January 17, 2006, 06:05:44 pm »
Yes you have to use the non shouldered studs, I sell rubber valve cover gaskets with the non shouldered studs very often even for people using just the stock valve cover.
Reply #5April 13, 2006, 01:39:19 pm
YoSono
  • 22
« Reply #5 on: April 13, 2006, 01:39:19 pm »
i have a g60 rocker cover with the circular pcv valve like this one:
what do i do with the pcv valve, do i use the one from the g60, or the original gtd one? also, the gtd rocker cover has the mesh grill underneath the valve, whereas the g60 one doesn't, so what happens there? and does it just connect up to the pipework as per normal
heres a quick test fit i did at the weekend (before i began to clean the head)
looks like i'm gonna have to sort out a new cambelt cover, and shoulderless bolts too... would you consider posting one of those rocker cover gaskets n bolts to the UK?
would be v interested to know, as then i can justify having the cover painted up
cheers
lee
