General Information
Troubleshooting
No Compression
Topic: No Compression (Read 4831 times)
March 08, 2011, 10:20:49 am
sgeorgejr
Newbie
No Compression
March 08, 2011, 10:20:49 am »
Need help diagnosing. I just bored my 1.6 diesel and replaced it with a 1.0 mm oversized pistons. The car ran but was smoking a lot after the rebuild. After compression check, 1,2,3 had almost 400psi and 4 had 0. The pistons are brand new. I am suspecting a bent valve, but by eye, they look ok. The old piston broke on the old engine, so that is why it needed a boring/rebuild. is there anything i am missing?
March 08, 2011, 10:42:30 am
Re: No Compression
March 08, 2011, 10:42:30 am »
On a fresh engine some smoke is very normal... sometimes they smoke quite a bit.
A couple of questions:
- is the hole with the low compression the same hole that broke the piston the last time??
- was there any headwork performed while you had the engine apart?
- did you seat the rings during the first 20 minutes of run-time?
A valve that's not seating or some broken rings in #4 would account for low compression.. although 0 is really low!
March 08, 2011, 02:00:57 pm
sgeorgejr
Newbie
Re: No Compression
March 08, 2011, 02:00:57 pm »
Thanks for the reply,
The no compression was the same as the one which broke the piston, and i did not perform any head work (although i just sent it out today to get checked). I did not reset the piston rings. The car did not run for over 20 minutes.
March 08, 2011, 02:07:47 pm
maxfax
Re: No Compression
March 08, 2011, 02:07:47 pm »
I'd bet one of your valves on that cyl is tweaked a bit.. Just eyeballing them they can look fine, but not be perfectly sealed..
0 compression is impressively low..Did you notice an odd "hissing" sound from the exhaust or intake when cranking or running??
March 08, 2011, 03:55:50 pm
Quantum TD
Re: No Compression
March 08, 2011, 03:55:50 pm »
If you had done valve work, I would have guessed that your valve shims were too thick. But since you didn't, I'm guessing everyone else is on track with bent valve.
March 09, 2011, 09:31:52 am
Re: No Compression
March 09, 2011, 09:31:52 am »
how on earth did you CRACK/BREAK a piston?!?!?!
March 09, 2011, 04:51:24 pm
sgeorgejr
Newbie
Re: No Compression
March 09, 2011, 04:51:24 pm »
2 bent valves......thanks for the replies. I didnt break the piston, the last owner did. not sure what happened, but it was mine to fix for $400 so i took the chance.
March 09, 2011, 05:06:31 pm
maxfax
Re: No Compression
March 09, 2011, 05:06:31 pm »
Were they both on the dead cylinder???
March 17, 2011, 04:53:21 pm
sgeorgejr
Newbie
Re: No Compression
March 17, 2011, 04:53:21 pm »
yes they were. valves must have wacked the broken cylinder
General Information
Troubleshooting
No Compression
