Author Topic: No Compression  (Read 4821 times)
March 08, 2011, 10:20:49 am
sgeorgejr
  • 11
No Compression
« on: March 08, 2011, 10:20:49 am »
Need help diagnosing.    I just bored my 1.6 diesel and replaced it with a 1.0 mm oversized pistons.   The car ran but was smoking a lot after the rebuild.  After compression check, 1,2,3 had almost 400psi and 4 had 0.  The pistons are brand new.  I am suspecting a bent valve, but by eye, they look ok.  The old piston broke on the old engine, so that is why it needed a boring/rebuild. is there anything i am missing?
Reply #1March 08, 2011, 10:42:30 am
Re: No Compression
« Reply #1 on: March 08, 2011, 10:42:30 am »
On a fresh engine some smoke is very normal... sometimes they smoke quite a bit.
A couple of questions:
- is the hole with the low compression the same hole that broke the piston the last time??
- was there any headwork performed while you had the engine apart?
- did you seat the rings during the first 20 minutes of run-time?
A valve that's not seating or some broken rings in #4 would account for low compression.. although 0 is really low!
Reply #2March 08, 2011, 02:00:57 pm
sgeorgejr
  • 11
Re: No Compression
« Reply #2 on: March 08, 2011, 02:00:57 pm »
Thanks for the reply,
The no compression was the same as the one which broke the piston, and i did not perform any head work  (although i just sent it out today to get checked).   I did not reset the piston rings.   The car did not run for over 20 minutes.
Reply #3March 08, 2011, 02:07:47 pm
maxfax
  • 2126
Re: No Compression
« Reply #3 on: March 08, 2011, 02:07:47 pm »
I'd bet one of your valves on that cyl is tweaked a bit..  Just eyeballing them they can look fine, but not be perfectly sealed..
0 compression is impressively low..Did you notice an odd "hissing" sound from the exhaust or intake when cranking or running??
Reply #4March 08, 2011, 03:55:50 pm
Quantum TD
  • 1195
Re: No Compression
« Reply #4 on: March 08, 2011, 03:55:50 pm »
If you had done valve work, I would have guessed that your valve shims were too thick. But since you didn't, I'm guessing everyone else is on track with bent valve.
Reply #5March 09, 2011, 09:31:52 am
Re: No Compression
« Reply #5 on: March 09, 2011, 09:31:52 am »
how on earth did you CRACK/BREAK a piston?!?!?!  :o
Reply #6March 09, 2011, 04:51:24 pm
sgeorgejr
  • 11
Re: No Compression
« Reply #6 on: March 09, 2011, 04:51:24 pm »
2 bent valves......thanks for the replies.   I didnt break the piston, the last owner did.    not sure what happened, but it was mine to fix for $400 so i took the chance.
Reply #7March 09, 2011, 05:06:31 pm
maxfax
  • 2126
Re: No Compression
« Reply #7 on: March 09, 2011, 05:06:31 pm »
Were they both on the dead cylinder???
Reply #8March 17, 2011, 04:53:21 pm
sgeorgejr
  • 11
Re: No Compression
« Reply #8 on: March 17, 2011, 04:53:21 pm »
yes they were.  valves must have wacked the broken cylinder
