For Sale/Looking For
Parts for Sale/Wanted
WTB: diesel fuel filter bracket/thing & other stuff
Topic: WTB: diesel fuel filter bracket/thing & other stuff (Read 7794 times)
March 08, 2011, 02:01:50 am
Digital K
March 08, 2011, 02:01:50 am »
mk1 stuff needed:
fuel filter bracket. preferably off of a mk1
5spd linkage bits. cage, and arms etc
AAZ water pipe from pump to core. apparently the rabbit one doesnt fit.
AAZ upper and lower timing cover.
I also need whatever hose I need that goes from the turbo to the intake manifold. The one I have doesnt seem to reach. I did put a different exhaust manifold on than was on the motor.
thanks in advance...
Last Edit: March 08, 2011, 02:03:34 am by Digital K
March 08, 2011, 06:07:05 am
GEE-BEE
Re: WTB: diesel fuel filter bracket/thing & other stuff
March 08, 2011, 06:07:05 am »
samba on the 5 speed linkage parts
vwdieselparts.com on the water pipe
http://www.hansdieselparts.com/037121065LWaterPipe.htm
YOU WILL NEED THIS ALSO ,for the darrd line to the heater valve
http://cgi.ebay.com/ebaymotors/VW-Rabbit-Scirocco-Water-Pump-Hose-Lifetime-Silicone-_W0QQcmdZViewItemQQhashZitem33644e867eQQitemZ220726199934QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
timing cover samba also, there was a guy on there with metal one's
my seller has the intake duct, ebay MK1 autohaus
http://cgi.ebay.com/ebaymotors/VW-Rabbit-Jetta-1-6-TD-1-9-AAZ-Silicone-Boost-Hose-Blk-_W0QQcmdZViewItemQQhashZitem335e39ca52QQitemZ220624177746QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesall
color's
he also stock the intake snorkel, now just find a mk1 TD airbox assyhttp://cgi.ebay.com/ebaymotors/VW-Rabbit-Mk1-Golf-Caddy-1-6-TD-Snorkel-Air-Intake-Hose-_W0QQcmdZViewItemQQhashZitem33618973a2QQitemZ220679730082QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
If you are going the K&N type , than just use the stock aaz model and I have the filter assy here
RX4860
[email protected]
Last Edit: March 08, 2011, 06:34:21 am by GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
March 08, 2011, 06:10:29 am
GEE-BEE
March 08, 2011, 06:10:29 am »
What radiator are you going with ?
stock were either 525mm or 568mm
675 mm mkii non a/c are cheaper and I make the hoses upper and lower and I also make the 3 engine hoses if you want..
http://www.autohausaz.com/search/product.aspx?sid=z2lpkc55toyksz55ht3c3r55&makeid=800026@VW&modelid=1285657@SCIROCCO
16-VALVE&year=1988&cid=16@Cooling System&gid=2172@Radiator
74.19 new
1.9 aaz assy's
pump to head , t to oil cooler
pump to oil oil cooler and hardline
hardline to resv tank
GB
Last Edit: March 08, 2011, 06:42:58 am by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
March 08, 2011, 07:34:44 am
GEE-BEE
March 08, 2011, 07:34:44 am »
Here is the upper, Iam not sure if the lower 1.6 will fit the 1.9 ?
http://www.thesamba.com/vw/classifieds/detail.php?id=932657
I will have to get a Upper and powder coat also
GB
Giles Pump OHC
MK1 JETTA DASH
March 08, 2011, 08:57:33 am
March 08, 2011, 08:57:33 am »
I have the MK1 fuel filter bracket, looks almost new.
Do you also need the clear molded tubing with the banjo bolt that goes between the fuel filter housing and the injection pump?
$15 w/o the tube.
$20 with the tube.
Prices include non-priority shipping via U.S. mail assuming you are in MN. Send me a message if interested or if you want pics.
March 08, 2011, 02:25:23 pm
Digital K
March 08, 2011, 02:25:23 pm »
thats the rad I am going with. I dont want an overflow reservoir.
price seems a bit high for the filter bracket. I'll let you know if I dont find something soon.
Thanks for the parts finding help guys
I take it the timing covers are hard to find new? per the boost hose, I am probably going to go from the turbo into the raintray. I do plan on intercooling at some point so I dont think I can run a stock airbox and stuff quite as easily I presume?
Last Edit: March 08, 2011, 02:28:53 pm by Digital K
March 08, 2011, 04:00:27 pm
GEE-BEE
March 08, 2011, 04:00:27 pm »
only if you turn the intake or go with a PD130 intake
2.50 to 2.00 silicone coupling
racepipe adapter off the PD130
What turbo ?
I wouldnt run that radiator, why do you think they went to 675mm in the 1991 golf 1.6 td ?
besides, that radiator look's like junk..
GB
Last Edit: March 08, 2011, 04:02:57 pm by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
March 08, 2011, 04:03:14 pm
GEE-BEE
March 08, 2011, 04:03:14 pm »
here's a new line
http://cgi.ebay.com/ebaymotors/Cohline-Diesel-Fuel-Line-_W0QQcmdZViewItemQQhashZitem4cf59e4ae4QQitemZ330538306276QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Vw-Rabbit-Jetta-Pickup-Turbo-Diesel-Filter-Pump-Hose-_W0QQcmdZViewItemQQhashZitem53e4215b8bQQitemZ360309676939QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
BANJO'S AND WASHERS ARE EXTRA
MK1autohaus has those also
Last Edit: March 08, 2011, 04:06:52 pm by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
March 08, 2011, 04:03:54 pm
GEE-BEE
March 08, 2011, 04:03:54 pm »
hey Baja
I will take it
Giles Pump OHC
MK1 JETTA DASH
March 08, 2011, 05:24:48 pm
Digital K
March 08, 2011, 05:24:48 pm »
oh that line....I wont need the line, but will take it w/out the line.
radiator shown is not my radiator, just an internet find radiator. I'll be getting a new one. I'll make a custom shroud w/ two slim fans.
I've ran that radiator in many applications. From a g60, to an ABA, to a PL, or a 9A, or even with a high compression 16v ABA hybrid with dual DCOE weber carbs. I have had no issues in any conditions.
March 08, 2011, 07:55:07 pm
Digital K
March 08, 2011, 07:55:07 pm »
here is the turbo I have. notice how bulged the original charge pipe elbow is. Im not sure what turbo it is. can anyone help?
also, does anyone need this stuff? would trade for any of the parts I need, or sell for cheap. I dont need it.
Reply #11
March 08, 2011, 10:17:15 pm
GEE-BEE
Reply #11 on:
March 08, 2011, 10:17:15 pm »
read the blue i.d. tag or show me the exhaust flange
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #12
March 08, 2011, 11:53:25 pm
Digital K
Reply #12 on:
March 08, 2011, 11:53:25 pm »
I'm imagining kkk k14. I'd have to actually look. but its the offset 4 bolt. I did find gaskets for it
