Author Topic: WTB: diesel fuel filter bracket/thing & other stuff  (Read 7798 times)
March 08, 2011, 02:01:50 am
Digital K
  • 58
« on: March 08, 2011, 02:01:50 am »
mk1 stuff needed:
fuel filter bracket. preferably off of a mk1
5spd linkage bits. cage, and arms etc
AAZ water pipe from pump to core. apparently the rabbit one doesnt fit.
AAZ upper and lower timing cover.
I also need whatever hose I need that goes from the turbo to the intake manifold. The one I have doesnt seem to reach. I did put a different exhaust manifold on than was on the motor.
thanks in advance...
« Last Edit: March 08, 2011, 02:03:34 am by Digital K »
Reply #1March 08, 2011, 06:07:05 am
GEE-BEE
  • 1604
Re: WTB: diesel fuel filter bracket/thing & other stuff
« Reply #1 on: March 08, 2011, 06:07:05 am »
samba on the 5 speed linkage parts
vwdieselparts.com on the water pipe
http://www.hansdieselparts.com/037121065LWaterPipe.htm
YOU WILL NEED THIS ALSO ,for the darrd line to the heater valve
http://cgi.ebay.com/ebaymotors/VW-Rabbit-Scirocco-Water-Pump-Hose-Lifetime-Silicone-_W0QQcmdZViewItemQQhashZitem33644e867eQQitemZ220726199934QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
timing cover samba also, there was a guy on there with metal one's
my seller has the intake duct, ebay MK1 autohaus
 http://cgi.ebay.com/ebaymotors/VW-Rabbit-Jetta-1-6-TD-1-9-AAZ-Silicone-Boost-Hose-Blk-_W0QQcmdZViewItemQQhashZitem335e39ca52QQitemZ220624177746QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesall color's
he also stock the intake snorkel, now just find a mk1 TD airbox assyhttp://cgi.ebay.com/ebaymotors/VW-Rabbit-Mk1-Golf-Caddy-1-6-TD-Snorkel-Air-Intake-Hose-_W0QQcmdZViewItemQQhashZitem33618973a2QQitemZ220679730082QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
If you are going the K&N type , than just use the stock aaz model and I have the filter assy here
RX4860
[email protected]
« Last Edit: March 08, 2011, 06:34:21 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2March 08, 2011, 06:10:29 am
GEE-BEE
  • 1604
« Reply #2 on: March 08, 2011, 06:10:29 am »
What radiator are you going with ?
stock were either 525mm or 568mm
675 mm mkii non a/c are cheaper and I make the hoses upper and lower and I also make the 3 engine hoses if you want..
http://www.autohausaz.com/search/product.aspx?sid=z2lpkc55toyksz55ht3c3r55&makeid=800026@VW&modelid=1285657@SCIROCCO 16-VALVE&year=1988&cid=16@Cooling System&gid=2172@Radiator
74.19 new
1.9 aaz assy's
pump to head , t to oil cooler
pump to oil oil cooler and hardline
hardline to resv tank
GB
« Last Edit: March 08, 2011, 06:42:58 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #3March 08, 2011, 07:34:44 am
GEE-BEE
  • 1604
« Reply #3 on: March 08, 2011, 07:34:44 am »
Here is the upper, Iam not sure if the lower 1.6 will fit the 1.9 ?
http://www.thesamba.com/vw/classifieds/detail.php?id=932657
I will have to get a Upper and powder coat also
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #4March 08, 2011, 08:57:33 am
« Reply #4 on: March 08, 2011, 08:57:33 am »
I have the MK1 fuel filter bracket, looks almost new.
Do you also need the clear molded tubing with the banjo bolt that goes between the fuel filter housing and the injection pump?
$15 w/o the tube.
$20 with the tube.
Prices include non-priority shipping via U.S. mail assuming you are in MN. Send me a message if interested or if you want pics.
Reply #5March 08, 2011, 02:25:23 pm
Digital K
  • 58
« Reply #5 on: March 08, 2011, 02:25:23 pm »
thats the rad I am going with. I dont want an overflow reservoir.
price seems a bit high for the filter bracket. I'll let you know if I dont find something soon.
Thanks for the parts finding help guys :) I take it the timing covers are hard to find new? per the boost hose, I am probably going to go from the turbo into the raintray. I do plan on intercooling at some point so I dont think I can run a stock airbox and stuff quite as easily I presume?
« Last Edit: March 08, 2011, 02:28:53 pm by Digital K »
Reply #6March 08, 2011, 04:00:27 pm
GEE-BEE
  • 1604
« Reply #6 on: March 08, 2011, 04:00:27 pm »
only if you turn the intake or go with a PD130 intake
2.50 to 2.00 silicone coupling
racepipe adapter off the PD130
What turbo ?
I wouldnt run that radiator, why do you think they went to 675mm in the 1991 golf 1.6 td ?
besides, that radiator look's like junk..
GB
« Last Edit: March 08, 2011, 04:02:57 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #7March 08, 2011, 04:03:14 pm
GEE-BEE
  • 1604
« Last Edit: March 08, 2011, 04:06:52 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #8March 08, 2011, 04:03:54 pm
GEE-BEE
  • 1604
« Reply #8 on: March 08, 2011, 04:03:54 pm »
hey Baja
I will take it
Giles Pump OHC
MK1 JETTA DASH
Reply #9March 08, 2011, 05:24:48 pm
Digital K
  • 58
« Reply #9 on: March 08, 2011, 05:24:48 pm »
oh that line....I wont need the line, but will take it w/out the line.
radiator shown is not my radiator, just an internet find radiator. I'll be getting a new one. I'll make a custom shroud w/ two slim fans.
I've ran that radiator in many applications. From a g60, to an ABA, to a PL, or a 9A, or even with a high compression 16v ABA hybrid with dual DCOE weber carbs. I have had no issues in any conditions.
Reply #10March 08, 2011, 07:55:07 pm
Digital K
  • 58
« Reply #10 on: March 08, 2011, 07:55:07 pm »
here is the turbo I have. notice how bulged the original charge pipe elbow is. Im not sure what turbo it is. can anyone help?
also, does anyone need this stuff? would trade for any of the parts I need, or sell for cheap. I dont need it.
Reply #11March 08, 2011, 10:17:15 pm
GEE-BEE
  • 1604
« Reply #11 on: March 08, 2011, 10:17:15 pm »
read the blue i.d. tag or show me the exhaust flange
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #12March 08, 2011, 11:53:25 pm
Digital K
  • 58
« Reply #12 on: March 08, 2011, 11:53:25 pm »
I'm imagining kkk k14. I'd have to actually look. but its the offset 4 bolt. I did find gaskets for it :)
