Author Topic: Intercooler  (Read 3921 times)
January 15, 2006, 07:01:22 am
Malacaco
  • 51
Intercooler
« on: January 15, 2006, 07:01:22 am »
I was thinking about insatlling an intercooler in my 1.6 gtd with k24 turbocharger. What is the best and cheapest solution to make?
1983 VW Golf MKI with swapped engine (1.6D to 1.6TD)
http://batracer.com/-1FrontPage.htm?1E.
--->check it out
Reply #1January 15, 2006, 07:10:48 am
VWRacer
  • 649
Intercooler
« Reply #1 on: January 15, 2006, 07:10:48 am »
Factory GTDs came with an intercooler under the bonnet. Or are you converting a TD to a GTD? If so, maybe the easiest and cheapest IC is one from a wrecked TDI.
Stan
C-Sports Racer
Reply #2January 15, 2006, 07:21:42 am
Malacaco
  • 51
Intercooler
« Reply #2 on: January 15, 2006, 07:21:42 am »
Well, mine was a NA originaly, then i got a td engine, but it had no intercooler. Is the tdi intercooler compatible with the td engine?
--->check it out
Reply #3January 15, 2006, 02:33:08 pm
Intercooler
« Reply #3 on: January 15, 2006, 02:33:08 pm »
Quote from: "Malacaco"
any intercooler would be compatible as long as you can make it fit :)
Reply #4January 16, 2006, 03:20:14 am
mk1vdub
  • 93
Intercooler
« Reply #4 on: January 16, 2006, 03:20:14 am »
Quote from: "jtanguay"
exactly
this is what I've got in my mk1 GTD:
see thia thread for more pics:http://www.vwdiesel.net/phpBB/viewtopic.php?p=13412&highlight=#13412
its from a land rover TD5 - I basically just had a look on ebay and bought the biggest one with basically the right dimensions to fit, it did take a bit of fettling but it only cost me about £40 so I'm pretty happy :)
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
Reply #5January 16, 2006, 03:50:59 am
Intercooler
« Reply #5 on: January 16, 2006, 03:50:59 am »
yea the surface area on that intercooler is huge.. will definitely help cool much better than a smaller one
Reply #6January 16, 2006, 04:45:26 am
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
Intercooler
« Reply #6 on: January 16, 2006, 04:45:26 am »
Can you post some dimensions of that land rover IC?
Excuse me on my bad English
Reply #7January 28, 2006, 10:55:20 am
mk1vdub
  • 93
Intercooler
« Reply #7 on: January 28, 2006, 10:55:20 am »
hey sorry entuzijast
I have been meaning to get the dimensions for you but it meant actually being in the right place at the right time with a tape measure! :roll:
the core size is:
26" wide - 9 1/2" high - 1 1/2" deep
with the end caps adding a couple of inches either side, about half an inch to the height and a couple of inches to the depth.
another pic to help:
HTH :)
1983 mk1 golf GTD
Reply #8January 29, 2006, 11:33:25 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
Intercooler
« Reply #8 on: January 29, 2006, 11:33:25 am »
I started installing this huge Volvo 5cyl petrol turbo intercooler I got for the grand sum of £10 [:)] in my GTD, though I removed it because to pipe it up I'd have to move the battery
Click the pics for larger 1024x768 versions
I had to grind the front of the lower radiator support to get it to fit and I'm going to have to fit the battery in the boot so I can route the intercooler outlet tubing.  unless I can move it over, dont know if I tried that or not as I fitted it ages ago and removed it the next day.
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #9January 29, 2006, 12:13:20 pm
entuzijast
  • 73
Intercooler
« Reply #9 on: January 29, 2006, 12:13:20 pm »
Thank's mk1vdub :)
