Author Topic: Don't use the A/C.. can I just snip the A/C Compressor belt?  (Read 5917 times)
January 13, 2006, 03:24:24 pm
RustyRabbit
  • 33
« on: January 13, 2006, 03:24:24 pm »
In order to make putting a new alternator belt on very easy?
Or would this screw up my engine?
Thanks    :|
Reply #1January 13, 2006, 04:16:05 pm
vwmike
  • 1158
« Reply #1 on: January 13, 2006, 04:16:05 pm »
There shouldn't be a problem running the engine without the A/C belt.
Reply #2January 13, 2006, 04:34:55 pm
RustyRabbit
  • 33
« Reply #2 on: January 13, 2006, 04:34:55 pm »
that's good to hear.  Thanks for all of your help.
Reply #3January 13, 2006, 05:10:18 pm
vwmike
  • 1158
« Reply #3 on: January 13, 2006, 05:10:18 pm »
That belt doesn't drive anything else, does it?
Reply #4January 13, 2006, 05:34:40 pm
RustyRabbit
  • 33
« Reply #4 on: January 13, 2006, 05:34:40 pm »
That's a good question.  I know its attached to another pully, but I'm not sure what it is.  I'll check my new Bentley manual to see what's what.
Reply #5January 14, 2006, 09:41:11 pm
RustyRabbit
  • 33
« Reply #5 on: January 14, 2006, 09:41:11 pm »
I found out that that other belt that is on the A/C compressor also spins the water pump, so no more belt cutting in the picture...  I wonder how the heck to loosen that belt!? :(
Reply #6June 07, 2006, 11:55:35 am
arfalberg
« Reply #6 on: June 07, 2006, 11:55:35 am »
use a allen head wrench and remove the main pully and the waterpump pully.  thay take the same size wrench.  after they are removed it is no problems from there.  i did it last night and had the alt belt re-placed in 30 min and the car running again.
Reply #7June 09, 2006, 03:37:23 pm
« Reply #7 on: June 09, 2006, 03:37:23 pm »
these belts suck... but a/c is nice  8)
there is a 400 dollar serpentine belt kit available... wonder if its worth it? (big chunk of change...)
Reply #8June 30, 2006, 12:45:34 pm
MaxHedrm
  • 114
    • blog
« Reply #8 on: June 30, 2006, 12:45:34 pm »
Quote from: jtanguay
& then when one goes they all go.  :?
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #9June 30, 2006, 09:24:28 pm
coke
  • 254
« Reply #9 on: June 30, 2006, 09:24:28 pm »
I've seen the advertised serpentine conversion kit. I can also tell you from experience, I've never witnessed or had a serpentine belt break on a car. Just replace it every 60-80k miles, cheap insurance.
The thing that turned me off to the kit was the fact that I would still have to use a v-belt to drive my power steering pump, which pisses me off because my power steering pump is eating belts left and right, and the car is a hard car to steer without it. :|
