Author Topic: WTB soft green advance spring  (Read 4784 times)
February 02, 2011, 03:40:05 pm
truckinwagen
  • 1895
« on: February 02, 2011, 03:40:05 pm »
hey all, I am interested in buying an advance spring from a vw injection pump.
specifically the softest that was available, I believe it was the green one.
if anyone has one lying around, or one in a core pump that they would not mind letting go of, I would be greatful
gotta get this isuzu running right!
-Owen
83 Opel Kadett Diesel
Reply #1February 02, 2011, 03:46:46 pm
Re: WTB soft green advance spring
« Reply #1 on: February 02, 2011, 03:46:46 pm »
I will see what I have in the mech 1.6 TD. I don't know what springs the TD's had, but I thought the green spring was real early 1.6 maybe only the 1.5 in all but the vanagon. The Vanagon for sure had the green spring and it was in the 1.6...I am just saying that there may have been more than that AND that a 12mm TD block may not have what you are looking for. I will still look though.
Reply #2February 02, 2011, 04:55:22 pm
truckinwagen
  • 1895
« Reply #2 on: February 02, 2011, 04:55:22 pm »
that would be cool, whatever it came out of, I need one!
-Owen
Reply #3February 02, 2011, 07:40:19 pm
  • 2931
« Reply #3 on: February 02, 2011, 07:40:19 pm »
I think that's the spring in the 1.5 pumps: 107A.
 I've seen green spring in them before,.. and it makes sense, they have a steeper line.
Reply #4February 03, 2011, 05:26:57 pm
truckinwagen
  • 1895
« Reply #4 on: February 03, 2011, 05:26:57 pm »
anyone have one?
Please!!!!!
-Owen
Reply #5February 03, 2011, 08:18:03 pm
RadoTD
  • 513
    Stage WTF
« Reply #5 on: February 03, 2011, 08:18:03 pm »
What about a spring from a 1.9 pump? They're longer and softer... it has some preload when you put the pump cap on, but you could adjust the preload by cutting the spring. Might be too soft though
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #6February 03, 2011, 08:23:29 pm
truckinwagen
  • 1895
« Reply #6 on: February 03, 2011, 08:23:29 pm »
you have a pic of a 1.9 spring next to a 1.6?
how big is the length difference?
-Owen
Reply #7February 03, 2011, 10:20:29 pm
Powered by Spearco
  • 1203
« Reply #7 on: February 03, 2011, 10:20:29 pm »
I have one  ::).
I was hoping to save ahold of it but I've got other pumps to pillage from later.
I'll send a pic tomarrow.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #8February 03, 2011, 11:02:25 pm
truckinwagen
  • 1895
« Reply #8 on: February 03, 2011, 11:02:25 pm »
that would be sweet!
what would you want for it?
I just clearanced a timing spring cover to go with the new spring, so hopefully I can get this fixed really quick.
-Owen
Reply #9February 05, 2011, 02:22:26 pm
« Reply #9 on: February 05, 2011, 02:22:26 pm »
I can't get the cover off to get the spring out. I can't get it easily at least. I need to take off everything to get to it and the engine is rolling around on the ground. I don't have my engine stand and it is cold in my shed.
Basically I am whimping out on you, but at least I tried :D
Reply #10February 05, 2011, 03:59:58 pm
truckinwagen
  • 1895
« Reply #10 on: February 05, 2011, 03:59:58 pm »
thats cool, powered by spearco is hooking me up with an AAZ spring.
thanks anyway,
-Owen
