Author Topic: Resonator recomendations  (Read 7608 times)
Reply #15August 31, 2011, 10:45:25 pm
  • 3468
    • McScrubbins Body Wash
Re: Resonator recomendations
« Reply #15 on: August 31, 2011, 10:45:25 pm »
i replaced the resonator on my TD with a very big very cheap glasspack and it worked wonders. Very quiet.
Reply #16September 02, 2011, 08:29:53 am
« Reply #16 on: September 02, 2011, 08:29:53 am »
td is one thing, dont use a glasspack on a n/a tho... it will RAP soo bad..
Reply #17September 02, 2011, 07:25:32 pm
« Reply #17 on: September 02, 2011, 07:25:32 pm »
Does not. It sounds wickedly awesome. I have a straight pipe with a glass-pack on a 2" exhaust. I also have a fully shimmed governor, and the good exhaust note doesn't even start until 4000 rpm's.. Under 4000 it sounds like i have a full exhaust with muffler and resonator.
Reply #18September 02, 2011, 08:21:02 pm
maxfax
  • 2126
« Reply #18 on: September 02, 2011, 08:21:02 pm »
Pends on the glass pack..  I had some an uber cheap one on the old Rabbit..  It sounded kinda raspy, but I think there was something rattling around in it, and the rest of the exhaust was still stock....   Current car has about the same setup as Jeremy's, 2" with an opened up toilet bowl, and it does sound damn good.. Only complaint is the drone on the highway..  I'm debating about installing 2 glass packs next time around..  One under the floor where the resonator would go, and one in the standard location.. That should be just enough to be tolerable for me...
Reply #19September 03, 2011, 07:53:32 am
« Reply #19 on: September 03, 2011, 07:53:32 am »
Cherry bomb, cheapest glass pack you can buy I'm sure. ie. $30. lol
I have mine in between the down pipe and the shifter on my car, even with leaks the sound still comes out the tail pipe behind my rear driver tire. Don't have much in car noise, im sure if it were a completely sealed exhaust it would sound pretty quiet in car.
Reply #20September 03, 2011, 08:52:26 am
« Reply #20 on: September 03, 2011, 08:52:26 am »
ok, well idk what was up with my car, but it was LOUD!!
the 4-1 header did not help out noise levels..
the only time my n/a sounded stock, was at idle.. and you could still tell it had pipes..
my car was rappin by 1750rpms.. not even joking.
i had a header, and a straight pipe back to a no-name red glass pack, with a foot or so of tail pipe.. it was FUGGIN LOUD!!
there was no "nice sounding" about my exhaust system.. my passengers and i would always giggle about the pipes tho, so it was honestly worth it..
would i do it again? HELL NO!
Reply #21September 03, 2011, 03:09:06 pm
maxfax
  • 2126
« Reply #21 on: September 03, 2011, 03:09:06 pm »
We must have had the same red no name glass pack..  I'm sure having a header made things worse too..   The glass pack I have now (dunno what brand it is to be honest) is about twice the diameter of the red things, and most definitely made of a heavier gauge steel...
Reply #22September 06, 2011, 10:11:15 pm
ToddA1
  • 434
« Reply #22 on: September 06, 2011, 10:11:15 pm »
Yeah, as mentioned, my glasspack equipped car is very quiet, but it's also running through a muffler.  I'm not getting any raspiness or droning at all.
About the soot issue....  I can see that happening with a perforated cored resonator (or muffler) but the louvered styles should fare better.  The louvers should direct the soot away from the packing.  Even if not, my resonator was cheap enough that a replacement every few years wouldn't be an issue.
-Todd
Reply #23September 07, 2011, 12:47:49 pm
« Reply #23 on: September 07, 2011, 12:47:49 pm »
-Todd
well, being that a RESONATOR is HOLLOW, they should not clog with soot..
glass packs go THUD when you tap them with a metal object.
resonators, or blown out glass packs, go TINK when you tap them with a metal object..
and yes Brett, im sure we had the same glass packs. did yours almost make your ears ring too? mine was louder than any fart-can-equipped honda ive ever heard..
and it wasnt that raspy loud like a honda, it had a CRACK to it..
Reply #24September 07, 2011, 07:16:51 pm
ToddA1
  • 434
« Reply #24 on: September 07, 2011, 07:16:51 pm »
You are correct.  I mistakenly wrote resonator, when I meant glasspack;  I do know the difference.  For some reason, I referred to mine as a glasspack, and a resonator in the same post.
-Todd
Reply #25September 07, 2011, 07:46:40 pm
« Reply #25 on: September 07, 2011, 07:46:40 pm »
Mine definitely has a crack to it, its sounds GODLY. Like an old 6V92 when i get on it.
http://www.youtube.com/watch?v=dVjXwS8HzFw
Reply #26September 07, 2011, 07:49:41 pm
maxfax
  • 2126
« Reply #26 on: September 07, 2011, 07:49:41 pm »
That would be the sound..  It was for 2" pipe, and diameter at the fattest part was only maybe 3" - 4" I guess that's what you get for a $10 glass pack..    The one I have now is also for 2" pipe, but is 5" - 6" at the fattest part..  Impressive how much difference there is...
Reply #27September 08, 2011, 12:10:28 am
2strokesmoke
« Reply #27 on: September 08, 2011, 12:10:28 am »
Hi Guys,
On my 82 Caddy 1.6NA
I ran stock gasser Bosal exhaust (needed the extra $$ for other parts) and the truck had a new Bosal muffler and tail pipe on it,when I bought it.
No resonator in the system.
The Bosal muffler is center inlet and center outlet style oval shaped muffler.
So,I marked tail pipe orientation-then cut the tail pipe off- stuck a hole saw with extension in the muffler outlet and drilled thru the center baffle.
Now you can see right thru the muffler-inlet to outlet !
Then mig welded tailpipe back on.
The whole procedure took about 1-1/2 hours.
Made a nice difference in the power with a nice sounding exhaust !
No droning and quiet with windows up.
I'm a happy camper !
Total cost for exaust was under $75 (because I had the new muffler and tailpipe)
Mike
Reply #28September 08, 2011, 12:44:38 pm
« Reply #28 on: September 08, 2011, 12:44:38 pm »
if you drilled a hole in your muffler, its not still quiet.. or else you havent had it above 3k rpms with the new exhaust..
Reply #29September 08, 2011, 01:00:04 pm
« Reply #29 on: September 08, 2011, 01:00:04 pm »
I don't know, mine is  pretty much a hole through the middle, and its quieter above 3000 than below.
