Author Topic: Resonator recomendations  (Read 7630 times)
Reply #30September 08, 2011, 01:01:24 pm
Re: Resonator recomendations
« Reply #30 on: September 08, 2011, 01:01:24 pm »
I also did the  hole saw thing on my buddies powerstroke, and it's not notably loud.
Reply #31September 08, 2011, 01:09:24 pm
bagpipegoatee
« Reply #31 on: September 08, 2011, 01:09:24 pm »
I don't know, mine is  pretty much a hole through the middle, and its quieter above 3000 than below.
I like this resonator design, the Moroso spiral flow, it seems it's called.
Edit: doesn't seem to be available in enough sizes, I'd need 2 inch.   Looks like a turbo with glasspack is still the best solution.
« Last Edit: September 08, 2011, 01:15:03 pm by bagpipegoatee »
Reply #32September 08, 2011, 01:16:07 pm
« Reply #32 on: September 08, 2011, 01:16:07 pm »
thats a moroso spiral flow muffler.. its not a resonator, or a glass pack, but a welded muffler.. they are awesome..
we have a pair on our aluminum tube frame sand rail (500+ hp corvette 327 powered) and they are very pleasant at idle.. but once you get on it, you can definitely tell they are an OPEN muffler..
im sure on a TD they sound REALLY good..
Reply #33September 08, 2011, 10:37:57 pm
2strokesmoke
« Reply #33 on: September 08, 2011, 10:37:57 pm »
Believe it or not,It's not actually loud )probably because of the stock size pipes)
And I've only had it over 3500RPM 2X--when I missed a shift going into 5th entering the highway.(dumped into 3rd) With the gov mod-holy crap ! The exhaust was the last thing on my mind ! Redlined pretty damn quick-but didn't come apart. I had replaced all the shifter bushings and ball,but the adjustment wasn;t quite right.
You bet I adjusted that correctly,after that mishap.
Mike
Reply #34September 09, 2011, 02:14:53 pm
« Reply #34 on: September 09, 2011, 02:14:53 pm »
I have my governor modified, with it fully shimmed. I take the sum*** up past 5k every single time i drive it ;) LOVE IT. Sounds sooo good, I'll have to post a video.
Reply #35September 10, 2011, 12:24:53 pm
« Reply #35 on: September 10, 2011, 12:24:53 pm »
ok, well, idk whats wrong with your guys's cars, but mine was OBNOXIOUSLY loud.. and im a kid.. i like loud. and it was too loud for me..
Reply #36September 10, 2011, 12:31:27 pm
« Reply #36 on: September 10, 2011, 12:31:27 pm »
Probably had exhaust leaks and/or the exhaust didn't exit from under the vehicle..
I'm sorry but even my v8 straight off the long tubes wasn't too loud for me..
Kev ya just a kittykatt
