Author Topic: WTB upper timing valve cover for a 1.6td found it, forgot to update  (Read 7233 times)
January 17, 2011, 04:53:57 pm
somedumbjerk
  • 71
« Last Edit: June 21, 2011, 07:42:02 pm by somedumbjerk »
Reply #1January 17, 2011, 05:02:29 pm
coke
  • 254
Re: WTB upper timing valve cover for a 1.6td
« Reply #1 on: January 17, 2011, 05:02:29 pm »
Need to know what year. Some earlier ones used a metal cover, while the later models used a plastic one. Year/make/model. It is stock as far as you know? Like, someone didn't swap an older motor in it and just hack the P/S motor mount off vs changing the IP brackets/etc.
Reply #2January 18, 2011, 09:52:31 am
« Reply #2 on: January 18, 2011, 09:52:31 am »
its a timing BELT cover..
there be no valves under that cover.. they are under the one on the top of the engine.  8)
Reply #3January 18, 2011, 10:05:04 am
somedumbjerk
  • 71
« Reply #3 on: January 18, 2011, 10:05:04 am »
definitely had a motor swap. i'll take a look tonight and try and get the engine code.
thanks!
LOL i can't believe i typed that. wow.... that's almost quote worthy...
Reply #4January 18, 2011, 09:04:31 pm
  • 2932
« Reply #4 on: January 18, 2011, 09:04:31 pm »
Doesn't matter what the engine code is.
 What car are you putting it in?
 That determines what upper cover you need.
Reply #5January 19, 2011, 10:00:02 am
« Reply #5 on: January 19, 2011, 10:00:02 am »
thanks!
hahaha, this is a case of thinking one thing and typing another?
Reply #6January 19, 2011, 10:09:43 am
ilikevwdiesel
  • 1202
« Reply #6 on: January 19, 2011, 10:09:43 am »
hey sdj, you in Palo Alto?
My Bio
Reply #7January 22, 2011, 01:50:13 am
funkaholik
  • 88
    • http://funkaholik.tripod.com/index.html
« Reply #7 on: January 22, 2011, 01:50:13 am »
I'm in the East Bay and have a few timing belt covers.  Is the inside cover (against the engine) there? In that case you just need the outer piece.  It just clips on + one bolt.  Otherwise you need both pieces, and putting the inside piece on is a lot more complicated.  I may have both metal and plastic types.  Let me know what you need and I'll dig in some boxes.
Good to see there are some other IDI diesel drivers in the Bay Area...
Erik Miller
1981 VW Caddy - 1.6TD
2005 Infiniti G35 - Vortech supercharged, drinking E85
1967 Mustang - 390 4 speed - for sunny days
1970 Datsun SPL311 Roadster - hibernating...
Reply #8January 22, 2011, 08:42:22 am
« Reply #8 on: January 22, 2011, 08:42:22 am »
the metal cover has no plate that bolts to the engine. its basically the whole cover in one piece..
i like the plastic covers. they are way nicer to take off and put back on.
Reply #9January 22, 2011, 08:56:15 pm
sdwarf36
  • 159
« Reply #9 on: January 22, 2011, 08:56:15 pm »
I have a metal cover I'll trade for an upper plastic one--or i'd be interested in buying one. I also need 1 clip.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #10January 22, 2011, 10:11:59 pm
somedumbjerk
  • 71
« Reply #10 on: January 22, 2011, 10:11:59 pm »
Reply #11January 23, 2011, 02:57:01 am
ilikevwdiesel
  • 1202
« Reply #11 on: January 23, 2011, 02:57:01 am »
Yes sir.
you know my buddy Andrew from Richmond? That Jetta?
My Bio
Reply #12January 23, 2011, 10:29:06 am
sawedoffgolf
  • 213
« Reply #12 on: January 23, 2011, 10:29:06 am »
I have both covers for sale
Reply #13January 23, 2011, 11:57:31 am
« Reply #13 on: January 23, 2011, 11:57:31 am »
WOAH!
mk2 diesel cover.. theres something you dont see too often.
Reply #14January 23, 2011, 08:19:13 pm
somedumbjerk
  • 71
« Reply #14 on: January 23, 2011, 08:19:13 pm »
Yes sir.
i sure do! that jetta is what i need the timing cover for. he spoke very highly of you. that jetta is holding me over while i get my caddy all done up.
how much for the covers?
