Author Topic: Coolant Hose Mod for 1.9 AAZ , ( Aftermarket Oil Cooler Install )  (Read 4106 times)
January 06, 2011, 07:09:05 pm
GEE-BEE
  • 1604
Iam going to make a mandrell to remove the outlet hose to the factory oil cooler
VW Hose part # 037122058
This will make the removal of the factory oil cooler , as this new hose will take the coolant from the hardline to the pump with no connector to the oem oil cooler.
the other hose for this application is 068121053 E ( pump to head )
If you want to use a remote oil cooler filter, instead of the oem , these two hose assy's make it easier
Part # GB037122058-MOD
1 Piece silicone design, 5 ply
Delivery 1 week
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 06, 2011, 08:11:19 pm
tdihuntdawg
  • 27
Re: Coolant Hose Mod for 1.9 AAZ , ( Aftermarket Oil Cooler Install )
« Reply #1 on: January 06, 2011, 08:11:19 pm »
do you have any photos?
Reply #2January 06, 2011, 11:06:40 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #2 on: January 06, 2011, 11:06:40 pm »
yes, pictures would be very nice.
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #3January 07, 2011, 07:37:54 am
GEE-BEE
  • 1604
« Reply #3 on: January 07, 2011, 07:37:54 am »
Just look at the stock pic, remove the center hose that goes to the oem cooler
Iam going to make a black and red next week
Send me a email and I will send you a pic
[email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #4January 07, 2011, 08:24:08 am
« Reply #4 on: January 07, 2011, 08:24:08 am »
I love you...no homo. I was going to grab a set of your hoses for my 1.6. Then it hosed me.
I have to do the entire bucket of front end stut parts. I was going to do coilovers, but chickened out, plus I need it done this weekend. So I will have new BJ's :D, control arms, and all that to have a smooth nice ride.
Some day I will have a good set of hoses. Especially now that I won't have to plug the line for the stock oil cooler.
Reply #5January 07, 2011, 08:38:05 am
GEE-BEE
  • 1604
« Reply #5 on: January 07, 2011, 08:38:05 am »
I knew if I built it they would come.....
That's the funny thing , I figure if I need there must be others doing the same mod, Just a solution
36.00 with the two clamp's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #6January 08, 2011, 04:24:44 pm
  • 5104
« Reply #6 on: January 08, 2011, 04:24:44 pm »
Reply #7January 08, 2011, 05:06:36 pm
GEE-BEE
  • 1604
« Reply #7 on: January 08, 2011, 05:06:36 pm »
Thanx Trevor
Th large hose on the top of the pic , actually goes to the waterpump , Iam deleting the center hose that attaches to the OEM cooler, the other end connects to the coolant hardline
Giles Pump OHC
MK1 JETTA DASH
